March 10, 2011, 12:38 |
cyclic boundary condition
huxiaoxia
Rep Power: 16 |
I want to simulate the thin liquid film flow on the substrate and I need the periodic boundary condition for left, right, front and back sides of the domain. However, only the front and back sides work. When I put the cyclic BC on left and right, it shows the error "Attempt to cast type wall to type lduInterface". Does anyone know what's the problem and how to solve it? Thanks. |
March 10, 2011, 12:49 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi
This error shows up, because there is a mismatch between the boundary condition in your variables, i.e. type cyclic; , and the type of boundary condition in your boundary file in <case>/constant/polyMesh/boundary. In the latter, the boundary type is set to wall, but it should be set to cyclic. I have experienced problems in changing boundary type in my blockMeshDict and running blockMesh, however, this does not always change the boundary file. Best regards, Niels |
March 10, 2011, 14:12 |
cyclic BC
huxiaoxia
Rep Power: 16 |
Thanks a lot.
March 14, 2011, 15:18 |
Cyclic BC
David Aljure
Location: CTTC Universidad Politécnica de Catalunya. Spain
Rep Power: 15 |
Thanks for this, I was all afternoon trying to understand why the paraFOAM exited when I tryed to view the initial conditions (very knew to OF).
April 13, 2011, 07:34 |
#5 | |
HuyHoang
Rep Power: 15 |
Your subject happens to be my graduating thesis. I'm trying to set boundary condition for the case. Unfortunately, i don't know how to use the cyclic boundary condition, i can't set the pressure drop on the opposite cyclic planes like i did in fluent . Can you tell me how you set up your case, especially the cyclic boundary condition (i.e the pressure drop, the mass flow rate ). I use the solver InterDyMFoam. I investigates the openFoam - 1.6-ext example, the channel395 but it's seems helpless until now. I'm very grateful if you can help. Thanks in advance Hduy |
April 13, 2011, 08:37 |
#6 | |
maddalena
Rep Power: 23 |
mad |
April 13, 2011, 23:16 |
HuyHoang
Rep Power: 15 |
thank Maddalena
your comment have just saved my day :d Btw, last night i had a look at channel foam in the tutorial of OpenFoam. It use the pressure drop at two opposite cyclic planes to create a gradient pressure. I just have a thought to implement this method in the interDyMFoam solver. My work have just begun, do you have any recommend ? |
April 14, 2011, 03:30 |
#8 | |
maddalena
Rep Power: 23 |
mad |
April 14, 2011, 23:03 |
#9 |
HuyHoang
Rep Power: 15 |
Hi maddelena,
Have you ever tried the fan bc on the 3d case. I have some unexplainable result in simulation |
April 15, 2011, 04:09 |
#10 |
maddalena
Rep Power: 23 |
April 20, 2011, 11:30 |
cyclic BC
#11 |
huxiaoxia
Rep Power: 16 |
Dear HuyHoang:
Sorry to reply you late. First of all, in constant/polyMesh/blockMeshDic, you have to define the cyclic boundary, e.g cyclic back ( (0 2 3 1) (6 7 9 8) ) Then , when you define all the initial or boundary conditions under the folder 0, simply use the type cyclic. e.g back { type cyclic; } Is it clear for you? |
May 17, 2011, 07:07 |
setting cyclic BC
#12 |
Nicolas
Rep Power: 15 |
For a better understanding of OF, I'm trying to set up the Fluent's tutorials in OF. I'm currently working on the second tutorial about Modeling Periodic Flow and Heat Transfer, with periodic conditions. Here is what I've made: - copy the caelinux-1.7.0/run/tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/hotRoom tutorial; - delete the constant/polyMesh directory; - transform the mesh provided with Fluent's tutorial using the command Code:
fluentMeshToFoam -scale 0.01 tubebank.msh - copy and modify files from 0 to 1; - prompt a foamJob buoyantBoussinesqSimpleFoam. The point is the results are far from those obtained in Fluent, and I'm quite certain I've failed in setting up the cyclic BCs. It would be pretty nice if someone should help me. See the attachments for my case (due to its size, I can't join the mesh here nor the tutorial's pdf, but if you're interested in, I'd be pleased to send them by email) |
April 12, 2013, 03:20 |
#13 |
Esmaeil Ahmadiyan
Rep Power: 15 |
Hi dear foamers
I am working with dsmcFoam and trying to modeling a cyclic boundary conditions in a channel. My case is freeSpacePeriodic in /run/discriteMethods/dsmcFoam/freeSpacePeriodic directory. Boundary file in this case is as below: 6 ( xPeriodic_half0 { type cyclic; nFaces 256; startFace 14464; matchTolerance 0.0001; neighbourPatch xPeriodic_half1; } xPeriodic_half1 { type cyclic; nFaces 256; startFace 14720; matchTolerance 0.0001; neighbourPatch xPeriodic_half0; } yPeriodic_half0 { type cyclic; nFaces 320; startFace 14976; matchTolerance 0.0001; neighbourPatch yPeriodic_half1; } yPeriodic_half1 { type cyclic; nFaces 320; startFace 15296; matchTolerance 0.0001; neighbourPatch yPeriodic_half0; } zPeriodic_half0 { type cyclic; nFaces 320; startFace 15616; matchTolerance 0.0001; neighbourPatch zPeriodic_half1; } zPeriodic_half1 { type cyclic; nFaces 320; startFace 15936; matchTolerance 0.0001; neighbourPatch zPeriodic_half0; } ) Then I have changed this boundary file as below: 6 ( xPeriodic_half0 //(wall) { type wall; nFaces 256; startFace 14464; } xPeriodic_half1 //(outlet) { type cyclic; nFaces 256; startFace 14720; matchTolerance 0.0001; neighbourPatch yPeriodic_half0; } yPeriodic_half0 //(inlet) { type cyclic; nFaces 320; startFace 14976; matchTolerance 0.0001; neighbourPatch xPeriodic_half1; } yPeriodic_half1 //(wall) { type wall; nFaces 320; startFace 15296; } zPeriodic_half0 //(frontAndBack) { type empty; nFaces 320; startFace 15616; } zPeriodic_half1 //(frontAndBAck) { type empty; nFaces 320; startFace 15936; } ) But when I run this case give this error : --> FOAM FATAL ERROR: face 0 area does not match neighbour by 22.22222222% -- possible face ordering problem. patchutlet my area:64 neighbour area:80 matching tolerance:0.0001 Mesh face:1 fc-5 0 0) Neighbour fc0 4 0) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 220. FOAM exiting Please help me to resolve this error and please introduce a tutorial about cyclic BC modeling for me. Thanks a lot. Best regards e.ahmadiyan |
April 12, 2013, 04:52 |
#14 |
maddalena
Rep Power: 23 |
Hi e.ahmadiyan,
maybe more detail can help us to understand what you want to do. what openfoam version are you using? hat is your geometry? do you want to create cyclic or do you want to take given geometry and delete cyclic? mad |
April 12, 2013, 05:16 |
#15 |
Esmaeil Ahmadiyan
Rep Power: 15 |
Hi maddalena
Thanks for your reply I am using openFoam 2.0.1 and my geometry is a cubic L shape channel as show in the attached image Screenshot.jpg I want to give cyclic BC in inlet and outlet Best e.ahmadiyan |
April 12, 2013, 05:29 |
#16 | |
maddalena
Rep Power: 23 |
Answer is quite simple then...
My suggestion is to create a mesh using blockMesh or your preferred meshing software and then run createPatch. mad |
April 12, 2013, 05:55 |
#17 |
Esmaeil Ahmadiyan
Rep Power: 15 |
Whats your mean about two faces are not equal?
Could is salome be a good meshing software? What is your suggestion about preferred meshing software? In fact when we use of createPatch utility? Tanks again. Best. e.ahmadiyan |
April 12, 2013, 06:00 |
#18 |
maddalena
Rep Power: 23 |
Two faces are not equal since cell number is different!
You can use whatever you want as meshing software or utility. After you have a mesh, you use createPatch to crete cyclic. Good luck. mad |
April 12, 2013, 06:04 |
#19 |
Esmaeil Ahmadiyan
Rep Power: 15 |
Thanks dear maddalena
Good luck. e.ahmadiyan |
April 14, 2013, 13:50 |
#20 |
Esmaeil Ahmadiyan
Rep Power: 15 |
Hi dear maddalena
I have creates a mesh with salome and uses of createPatch and creates a cyclic BC but I have received to below error: FOAM Serious Error : From function cyclicPolyPatch:rder(const primitivePatch&, labelList&, labelList&) const No base point for face 15903, 4(5708 6065 6066 5709), produces a valid tet decomposition. All my test case... cyclic.zip Have you any suggestion? Best regards. e.ahadiyan Last edited by e.ahmadiyan; April 15, 2013 at 10:53. |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 06:05 |
Mixed/Robin boundary condition | aaev | OpenFOAM Bugs | 2 | December 15, 2011 15:03 |
cyclic boundary condition doesn't work in a tube ?? | Cyp | OpenFOAM | 6 | April 16, 2010 16:21 |
fan cyclic boundary condition | leejc | OpenFOAM | 0 | April 15, 2010 17:38 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 12:44 |
