cyclic boundary condition
Like Tree7Likes
Old   June 10, 2013, 10:30
Evangelos
Danath is on a distinguished road
If you convert your case from Fluent where you define the the cyclic boundary conditions .(Needless blockMeshDic)
Originally Posted by huxiaoxia View Post
Dear HuyHoang:
Sorry to reply you late. First of all, in constant/polyMesh/blockMeshDic, you have to define the cyclic boundary, e.g
cyclic back
(0 2 3 1)
(6 7 9 8)
Then , when you define all the initial or boundary conditions under the folder 0, simply use the type cyclic. e.g
back
type cyclic;
Is it clear for you?
Danath is offline   Reply With Quote
Old   July 5, 2013, 00:29
Mohammad
mohammad81 is on a distinguished road
Hi everyone.
I want to use cyclic (periodic) BC for cavity problem. it sounds simple. I want to use cyclic BC for both P and U (for inlet and outlet). I want to know what I have done is correct or not. Thank you.
This is blockMeshDict:
patches
wall topWall
(3 7 6 2)
wall bottomWall
(1 5 4 0)
cyclic inout
(0 4 7 3)
(2 6 5 1)
empty frontAndBack
(0 3 2 1)
(4 5 6 7)
This is my Boundary file:
4
topWall
type wall;
nFaces 40;
startFace 1540;
bottomWall
type wall;
nFaces 40;
startFace 1580;
inout
type cyclic;
nFaces 40;
startFace 1620;
featureCos 0.9;
frontAndBack
type empty;
nFaces 1600;
startFace 1660;
My 0/U is:
inout
type cyclic;
value uniform (0 0 0);
Finally 0/P is:
inout
type cyclic;
value uniform 0;
Is this correct? I got some result. I get the linear velocity and uniform pressure (Couette Flow). But I am not sure of it.
Is this type of using cyclic correct? what is this "neigbourpathc", "fan" etc..?
Thank you very much.
hua1015 likes this.
mohammad81 is offline   Reply With Quote
Old   July 10, 2013, 05:24
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Hi Dear mamad (oshtoli)
i think u need fan BC.
In OF the fan BC prescribes a pressure jump.
Note!The fan boundary condition is working on a cyclic patch.
defined in constant/polyMesh/boundary as
type cyclic;
and then in the pressure file 0/p:
type fan;
patchType cyclic;
f List<scalar> 2(10.0 -1.0);
value uniform 0;
The f above is a list of polynomial coefficients in the pressure jump definition
delta p = f_1 + f_2 * v + f_3 * v^2 + ...
Above only f_1 and f_2 is assigned, respectively 10.0 and -1.0.
In 0/U and so on, the ad patch is defined as cyclic.
any quastions are wellcome.
Rasoul
desert_1250 is offline   Reply With Quote
Old   October 31, 2014, 16:47
Default cyclic boundry condition
  #24
vahidshahabi is on a distinguished road
I want to simulate a channel flow in a periodically repeating geometry, the mesh generator is Gambit, I define my boundary conditions in gambit using "wall" not "periodic" or something else, after i converted the mesh with fluentMeshToFoam, in constant/polymesh/boundary i changed wall to cyclic for my periodic boundaries(inlet& outlet). As shown in blow
boundaryField
outlet
type cyclic;
neighbourPatch inlet;
inlet
type cyclic;
neighbourPatch outlet;
wall-h
type fixedValue;
value uniform 300;
wall-c
type fixedValue;
value uniform 200;
frontAndBackPlanes
type empty;
its ok, but after some times, I have following error message
FOAM FATAL ERROR, attemo to cast type patch to type LduInterface
FOAM aborting, foam::error:: print stack
Can you tell me how i solve this issue.
Thank you for your help.
vahidshahabi is offline   Reply With Quote
Old   November 3, 2014, 09:59
Nima Samkhaniani
nimasam is on a distinguished road
use AMIcyclic,instead, it may solve your problem
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   March 15, 2016, 06:57
Default dsmcFOAM BLOCKMESHDICT
  #26
avinash yadav
avinashy34 is on a distinguished road
HI
I AM FACING A PROBLEM TO UNDERSTAND
xPeriodic_half0
type cyclic;
faces ((1 2 6 5));
neighbourPatch xPeriodic_half1;
COMMAND WHAT IS THE ACTUAL MEAN OF THIS CAN ANYBODY HELP ME
avinashy34 is offline   Reply With Quote
Old   March 23, 2016, 02:53
Default Cyclic boundary definition
  #27
Maryam
Persia is on a distinguished road
Originally Posted by avinashy34 View Post
HI
xPeriodic_half0
type cyclic;
faces ((1 2 6 5));
It means that "xPeriodic_half0" is a cyclic patch, which is another term for periodic BC. "xPeriodic_half0" consists of the face with corner points 1, 2, 6, and 5, and its neighbour patch is patch "xPeriodic_half1". This means that "xPeriodic_half1" and "xPeriodic_half0" will have the same values for different parameters such as velocity, pressure, or temperature.
Persia is offline   Reply With Quote
Old   August 11, 2016, 18:16
Default cyclic Bc error
  #28
majid
majid pourdian is on a distinguished road
Hi
I have a simmulation with cyclic boundary condition and I get this error:
"Error in coupled point location"
when I change cyclic Bc to wall Bc error is disapeared.
could anyone help me?
majid pourdian is offline   Reply With Quote
Old   August 15, 2016, 02:46
Maryam
Originally Posted by majid pourdian View Post
Hi
Do the cyclic patches fully match geometrically?
Old   August 15, 2016, 17:17
majid
yes,I correct geometrically match error when I run blockMesh.now when I run checkMesh give me second error.
Old   August 16, 2016, 14:23
majid
Hi esmaeil
your neighbour patch should have equal area and mesh.
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
Mixed/Robin boundary condition aaev OpenFOAM Bugs 2 December 15, 2011 15:03
cyclic boundary condition doesn't work in a tube ?? Cyp OpenFOAM 6 April 16, 2010 16:21
fan cyclic boundary condition leejc OpenFOAM 0 April 15, 2010 17:38
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
