Changing patches vs changing mesh for multiple cases
Old   March 7, 2011, 17:37
Default Changing patches vs changing mesh for multiple cases
Greg Givogue
Greg Givogue is on a distinguished road
I have a questions about setting patches as inlets and outlets to achieve various angle of attacks on bodies. I would like to run several cases on one body at different angles of attack. I thought the easiest way to do this would be to orient the body in the x-direction in CAD and then mesh a rectangular domain - like a windtunnel. For the direct flow scenario (in the x-direction) I named the patch ahead of the body as an inlet and the the patch directly behind the body as on outlet. Simple enough, and this set-up gives good results. To get an angle of attack I assigned 2 patches as inlets and 2 patches as outlets and changed the initial conditions to include a y-component for U. In this set-up I then have an inlet patch touching an outlet patch...
I'm having issues with the cases involving an angle of attack and I need to question every setting. I would really appreciate some feedback - thanks in advance for your help and time!
Greg
Greg Givogue is offline   Reply With Quote
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
changing Mesh with known new points for shape kilerskill OpenFOAM 15 February 16, 2011 04:21
[mesh manipulation] How to delete selected cells from mesh and update boundary patches kaka OpenFOAM Meshing & Mesh Conversion 2 November 26, 2009 05:17
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
