InterFoam viscosity problem / possible bug
Like Tree9Likes
Old   July 15, 2012, 02:57
Ehsan
ehsan is on a distinguished road
Dear All
Please see Eq. 4 in the paper below:
http://www.marinepropulsors.com/proc...0Propulsor.pdf
May I ask you whether in OpenFOAM the same equation including turbulence effects are used for viscosity of two phase flow or only simple averaging from laminar values are employed?
Best Regards
ScarFace likes this.
ehsan is offline   Reply With Quote
Old   August 16, 2012, 18:47
David
salehda is on a distinguished road
any news about this issue , I am using a Herschel Bulkely model and tried setting the momentum predictor On or Off and I usually get unstability in case of turniing the momentum predictor on and less gravitional effect when turninhg it off ??
this problem is becoming annoying and i had no clue about it now!!1
salehda is offline   Reply With Quote
Old   October 29, 2012, 04:43
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Originally Posted by ehsan View Post
Dear All
Best Regards
Dear Ehsan,
please take a look at the interFoam solver. you will see sth like this:
surfaceScalarField muEff
"muEff",
twoPhaseProperties.muf()
+ fvc::interpolate(rho*turbulence->nut())
So OF will Consider both viscosities
Best Regards,
Mohsen
cfdonline2mohsen is offline   Reply With Quote
Old   January 31, 2020, 03:42
krishna kant
kk415 is on a distinguished road
Hello All
I am performing a test case of static bubble where the bubble column is kept at zero gravity. The test case is from M.Hermann paper http://multiphase.asu.edu/paper/jcp_2007.pdf of density and viscosity ratio 1. Here we plot La vs Ca to evaluate the spurious current generated. He has chosen viscosity=0.1, surface tension coefficient=1 and varied the density to vary the La number and obtain Ca of the order of 1e-6.
But for interFoam I am getting Ca of the order of 1e-4 for viscosity=0.1 and Ca of the order of 1e-6 for viscosity=1 keeping value of La same. Is it possible to get a solution independent of viscosity value for this problem? How can I optimize the solution parameters?
The current solution parameters that I am using is attached here.
kk415 is offline   Reply With Quote
Old   March 30, 2020, 05:25
Albrecht vBoetticher
vonboett is on a distinguished road
Hello
Your Mesh is qite coarse, as the volume-of-fluid method is quite sensitive to grid resolution. you have the same high density for water and air and your solution is affected by sigma in your transportProperties dict and your simulation neglects turbulence. I suggest you look at interFOAM tutorial cases.
vonboett is offline   Reply With Quote
interfoam, viscosity
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
flat plate boundary layer problem --great influence of viscosity waynezw0618 OpenFOAM 6 August 12, 2010 03:19
Problem with the pressure field using interFoam zoune OpenFOAM Running, Solving & CFD 20 February 4, 2008 19:42
Problem with InterFoam in_flu_ence OpenFOAM Running, Solving & CFD 4 October 26, 2007 09:39
Turbulent viscosity in a riser ap FLUENT 8 April 19, 2003 09:00
