natural convection ventilation
Old   February 20, 2011, 15:50
Default natural convection ventilation
Fabian Braennstroem
braennstroem is on a distinguished road
I am just trying to setup a small test case in 1.7.x for a generic HVAC case with two dummy cylinders placed in the room as a heat source with a heat flux boundary condition... I attached the case with the snappy mesh.
The meshing and running works fine... unfortunately there is no 'plume' development above the cylinder. The heat flux/power is set to 50W for the cylinder1 and it should give for this setup a velocity of around up to 0,2m/s at 40cm above the cylinder... I get something with 4e-5 m/s (just after 350 iterations, but this is still strange for me) !?
It is probably a quite stupid mistake, but I can't find it and would be happy, if one of you have a hint, what I am doing wrong with the setup!? I actually tried to upload the stl's as well, but they were a bit too large, so if someone needs them I would send it by mail.
Best Regards!
Fabian
Btw... the above counts for a relaxation factor of 1.0 for rho and not like in the fvSolution of 0.01 and the z-direction goes a long with the height of the room.
braennstroem is offline   Reply With Quote
Old   February 21, 2011, 03:37
Fabian Braennstroem
sorry bothering you, I was just not waiting long enough ;-)
After around 1500 iterations I could see that it goes in the right direction...
Old   March 28, 2011, 09:59
Default Luis
Luis Blanes
lmblanes is on a distinguished road
Hello Fabian
Which solver do you use to run the Code?
Thanks
lmblanes is offline   Reply With Quote
Old   March 29, 2011, 14:03
Fabian Braennstroem
buoyantSimpleFoam
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 05:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 05:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 20:43
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 19:43
natural convection in a sealed enclosure James Main CFD Forum 4 April 2, 2001 16:48
