Adjoint method
Old   February 16, 2011, 09:28
Default Adjoint method
Jens is on a distinguished road
Is there anybody who have experiences with the adjoint method to optimise a
geometry?
I implemented the adjoint equations based on papers and work of C. Othmers:
tmp<fvVectorMatrix> adUEqn
I think my problem is in the pressure correction. In all papers that i found they use the
simple method and i did it in the same way:
adp.boundaryField().updateCoeffs();
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix adpEqn
If I calculated adU there are values with 10^(11) or sometimes 10^(30) near the outlet-patch. I think that is not correct
Thanks for every comment.
Regards,
Jens
Jens is offline   Reply With Quote
Old   February 17, 2011, 03:50
Karl-Johan Nogenmyr
kalle is on a distinguished road
Hi!
I never tried this stuff, but I read somewhat about it earlier... are you sure about those boundary conditions? If I understood correctly, your cost function should come into the BC's for the adjoint eqs (if the cost function is described as a integral function over the domain). Check 'eq' 44-48 in C. Othmer, Int. J. Numer. Meth. Fluids 2008; 58:861–877
Regard,
K
kalle is offline   Reply With Quote
Old   February 17, 2011, 08:59
David Boger
boger is on a distinguished road
Jens,
Did the equations converge?
David A. Boger
boger is offline   Reply With Quote
Old   February 17, 2011, 09:34
Thanks for the replies.
@Kalle
I see your point and you are right, the BC's are one problem to solve and the equations are very sensitive to the BC's but the problem is ... that leads me to
@boger
No, that is the "main" problem/issue. The normal velocity converge but "adjoint U" dont converge. The problem is, if i print the divergence of adjoint velocity the values are very hight (16.xx or 0.1) but the priority/task of the pressure correction is the divergence of adjoint U is equal to zero. Well, I think the first problem to solve is that the pressure correction solve -> div(adjoint U) = 0. Isn't it?
The question is, is there a term missing or something else?
Regards,
Jens
Old   March 10, 2011, 02:47
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Hi Jens,
Is your pressure equation right?
I think the right hand side of this equation is the divergence of the adjoint velocity field.
Regards,
Fumiya
fumiya is offline   Reply With Quote
Old   March 10, 2011, 08:14
David Boger
Good point, Fumiya - you're correct!
David A. Boger
Old   March 10, 2011, 08:49
Thanks for your help and hints.
I got also a few hints by C. Othmer and the problem was the pressure equation.
Old   March 10, 2011, 22:49
fumiya's Avatar
Fumiya Nozaki
In my calculations, the continuity error of the adjoint velocity field does not drop compared to that of the primal velocity field.
1) Though there may be problems in my code, do the adjoint equations have this tendency?
2) Are the adjoint equations sensitive to the boundary conditions?
Do they converge with the same boundary conditions as the primal ones?
I would be grateful if you could share findings from your computations with the original solver from Dr. Othmer.
Regards,
Fumiya
Old   March 11, 2011, 04:36
The second problem was the boundary conditions ("kalle" his hint was right). You need special boundary conditions derived from the adjoint equations and the cost function on the boundary.
Regards,
Jens
Old   March 12, 2011, 06:55
BastiL
bastil is on a distinguished road
Jens,
thanks for the findings. How do these BCs look like?
Would you mind posting your final case and solver? Thanks.
Regards Bastian.
bastil is offline   Reply With Quote
Old   March 13, 2011, 11:39
Originally Posted by bastil View Post
Jens,
Regards Bastian.
Unfortunately, I cant.
Regards,
Jens
Old   March 14, 2011, 22:45
fumiya's Avatar
Fumiya Nozaki
I would be grateful if you could post contour plots of the adjoint pressure and
velocity fields for a simple duct when the cost function is dissipated power
and flow is laminar.
I would like to use these data for comparison with my results.
I will prepare a case if it could save your work.
Regards,
Fumiya
Old   March 16, 2011, 02:52
fumiya's Avatar
Fumiya Nozaki
I calculated surface sensitivities according to Dr. Othmer's article
when the cost function is dissipated power. In this calculation,
outlet boundary conditions are not properly imposed. I have to
implement new boundary conditions to obtain more precise results.
Regards,
Fumiya
Old   March 18, 2011, 04:11
Default SIMPLE algorithm
  #14
fumiya's Avatar
Fumiya Nozaki
I'm implementing the adjoint solver in OpenFOAM by myself.
Any comments are appreciated.
***************SIMPLE algorithm***************
//Momentum predictor step
//Define the equation for adU(adjoint velocity field)
fvm::div(-phi,adU) //Flux phi is obtained from the primal flow solutions
- (fvc::grad(adU) & U)
+ turbulence->divDevReff(adU)
//Under-relax(Inertial relaxation) the equation for adU
adUEqn().relax();
//Solve the momentum predictor using the last known adp(adjoint pressure field) on the RHS.
//This gives us a adjoint velocity field that is "not divergence free", but approximately satisfies momentum.
eqnResidual = solve
adUEqn() == -fvc::grad(adp)
).initialResidual();
maxResidual = max(eqnResidual, maxResidual);
//Update the boundary conditions for adp
//Pressure solution step(estimate a new pressure field
//that satisfies zero adjoint velocity divergence)
To be continued . . .
Old   June 12, 2011, 22:09
fumiya's Avatar
Fumiya Nozaki
I have run several cases and found it difficult to obtain a converged
solution. I think it is related to the adjoint transpose convection term.
What should I do to improve convergence of the adjoint equations?
Best regards,
fumiya
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 05:35
SQP method for adjoint based aerodynamic shape optimization cfdbooks Main CFD Forum 2 May 26, 2009 11:40
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 03:08
Adjoint method for error estimation Fab Main CFD Forum 0 May 27, 2008 03:11
A question about discrete adjoint method Thomas Main CFD Forum 3 August 9, 2006 13:37
