Temperature anomoly at pressure reference cell |
January 30, 2015, 09:11 |
#21 | |
Peng Liang
Rep Power: 12 |
by the way i want to ask you about how you can do that in gmsh. Because when i managed to generate structured mesh in wedge in gmsh with one layer in the rotation direction, all that seems perfect . But after that when i define physical surfaces and volumes, I tried to generate the mesh again , all the meshes turned back to unstructured and in the rotation direction there is not the one layer grid any more. And i looked into the .geo file and fund out that all the codes related with Extrude was disappeared. Sofar i have got no idea about why. Could you please tell me how to make wedge mesh in gmsh after define physical surfaces? Bests, Peng |
April 20, 2015, 03:14 |
#22 | |
Will Logie
Rep Power: 16 |
Although we're defining one in fvSolution with pRefCell/pRefPoint and pRefValue, isn't it superfluous? I've been running some simulations with Code:
p_rghEqn.setReference(pRefCell, getRefCellValue(p_rgh, pRefCell)); Last edited by will.logie; April 20, 2015 at 20:29. |
July 17, 2021, 00:26 |
#23 | |
Rep Power: 6 |
Installing OpenFOAM-1.5-dev on a cluster | ZKM | OpenFOAM Installation | 4 | December 25, 2010 16:59 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
