nutWallFunction vs. nutkWallFunction
Old   February 10, 2011, 09:26
Default nutWallFunction vs. nutkWallFunction
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I have been looking into the nut wall function behavior and found that there are two different nut wall function boundary conditions, one called
nutWallFunction
and the other one
nutkWallFunction
for some reason there is almost no difference, just that in the function
void nutkWallFunctionFvPatchScalarField::updateCoeffs()
    if (updated())
        return;
    operator==(calcNut());
    fixedValueFvPatchScalarField::updateCoeffs();
the if(updated()) is added to the nutkWallFunction but not to the nutWallFunction. Does anyone know why there is a difference and what it does?
~roman
romant is offline   Reply With Quote
Old   October 21, 2011, 11:12
FlowLy
giuli@ is on a distinguished road
I don't know the difference; however, I'm running openfoam 2.0.1 and there is no nutWallFunction available, only nutkWallFunction
giuli@ is offline   Reply With Quote
Old   March 6, 2016, 14:47
Gunnern is on a distinguished road
I am also wondering about the difference between the nutWallFunction and the nutkWallFunction. Does anyone have an idea?
Gunnern is offline   Reply With Quote
Old   March 7, 2016, 08:45
akidess's Avatar
Anton Kidess
nutWallFunction is a virtual base class.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   June 16, 2016, 13:43
Default nutkWallFunction
Mohamed Elghorab
crazzy.pirate43 is on a distinguished road
so if you please can you give more explanation as I tried to use it in OpenFoam 3.0.x and it was not existed as the run stop and if i may I need more data about nutkWallFunction
thank you in advance
crazzy.pirate43 is offline   Reply With Quote
wallfunctions
yPlusRAS and nutkWallfunction patch romant OpenFOAM Post-Processing 2 November 14, 2011 10:40
nutWallFunction questions madad2005 OpenFOAM 9 October 28, 2011 07:36
A few questions about Spalart Allmaras model and y seb62 OpenFOAM Running, Solving & CFD 8 January 15, 2011 14:09
nutWallFunction boundary condition AirS OpenFOAM Pre-Processing 6 March 3, 2010 08:31
