Help with pimpleFoam
Old   February 8, 2011, 07:37
Default Help with pimpleFoam
Francisco Cortés
fcortes is on a distinguished road
Hello everyone,
I’m using pimpleFoam to simulate a 3D flow on a very small irregular tube (total volume around 2e-7; 150000 elements (tetrahedral)). I’ve used the files of T-junction tutorial as a base. I’m also using GroovyBC to make the pulsatile velocity with a parabolic profile at the inlet and the pressure at the outlet. Turbulence model is a RAS kOmega and the fluid is Newtonian.
I’ve achieved convergence with pulses with top inlet velocity around 0.6 (Re=450). The minimum time step then was 1.8e-5. The problem is that I can’t achieve convergence with higher inlet velocities (Re=650 to 800). I’ve tried a lot of combinations of correctors (1 to 4), nonOrthogonalCorrectors (1 to 4), outerCorrectos (1 to 4), maxCo (1 to 0.5) and relaxation factors (1 to 0.05). I always get a blowout close to the top velocity but sometimes at a velocity lower than the top velocity of the case that worked, which to me is very weird.
If someone knows what I can do to solve this (or needs more info to do so) please let me know.
Thanks in advance!
Francisco
fcortes is offline   Reply With Quote
Old   June 26, 2014, 10:46
Ali reza
1988 is on a distinguished road
Hello Fransisco
I have ctuck in a problem the same as yours ,did you find an answer?
please help me tanks
1988 is offline   Reply With Quote
Old   June 26, 2014, 12:31
Francisco Cortés
Nop, I ended up simulating those cases in fluent.
Good luck!
groovybc, pimplefoam, pulsatile
Running stably with a large Courant number using pimpleFoam mlawson OpenFOAM 11 November 29, 2014 11:37
Restarting with pimpleFoam deinstein OpenFOAM 9 November 27, 2013 09:53
Problem running IDDES with pimpleFoam charlie OpenFOAM Running, Solving & CFD 7 July 11, 2013 12:45
tried with pimpleFoam and a big CFL = 5 ivan_cozza OpenFOAM Running, Solving & CFD 9 June 4, 2013 19:14
PimpleFoam problem Vadims.geza OpenFOAM 8 December 7, 2011 09:54
