k-omega SST and wall functions in OpenFOAM-1.5-dev
Like Tree36Likes
Old   September 9, 2016, 11:28
annn
cleoo is on a distinguished road
Originally Posted by mehrdad_kbg View Post
if some one is using low Reynolds number option of the SST kw it means that the flow has different layers and a very fine resolution of the mesh is required close to the wall. this needs a mesh with a y-plus less than at least 5. Therefore in this case no wall function can be used.
but isn't it always laminar flow very close to the wall? so should it have a low Reynolds number regardless?
cleoo is offline   Reply With Quote
Old   September 29, 2016, 11:26
Jack
Jack001 is on a distinguished road
I also have the very same question that Anne had many posts back, so I would just like to get clarification:
If I have a fine mesh which aims to resolve the boundary layer with y+ < 1 what boundary conditions are appropriate for the problem? Is the following correct for a wall patch? The current issue I have is that when I use the omegaWallFunction on my walls, I get a massive value of omega at the wall (about 1e8)
omegaWallPatch
    type        zeroGradient;
nutWallPatch
    type        calculated;
kWallPatch
    type        fixedValue;
    value       uniform 1e-10;
Jack001 is offline   Reply With Quote
Wall roughness and SST in 5.6 Louwrens CFX 7 November 21, 2014 12:10
k-omega simulation without wall functions vkrastev OpenFOAM 2 January 24, 2010 18:45
Wall function implementation K Omega SSt cbarry OpenFOAM 3 August 18, 2009 11:09
wall roughness with SST turbulence model in CFX10 Vincent CFX 7 September 10, 2007 17:49
SST model Autometic wall function parameters? David CFX 0 November 24, 2005 05:47
