1.6-ext: tutorial "turboPassageRotating" doesn't work |
January 16, 2011, 01:36 |
Masashi Ohbuchi
Rep Power: 17 |
Hi, all.
I've updated OpenFOAM-1.6-ext and successfully re-compiled on yesterday. But parallel computation of turboPassageRotating tutorial was failed. The error message as follows. ----------------------------------------------------------------------------------------------------------- Reading field p Initializing the GGI interpolator between master/shadow patches: rotor_cyclic_upper/rotor_cyclic_lower [0] [0] [0] --> FOAM FATAL IO ERROR: [0] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token [0] [0] file: IOstream at line 0. [0] [0] From function IOstream::fatalCheck(const char*) const [0] in file db/IOstreams/IOstreams/IOstream.C at line 109. [0] FOAM parallel run exiting [0] Reading field U Reading/calculating face flux field phi Reading field rAU if present [2] [2] [2] --> FOAM FATAL IO ERROR: [2] incorrect first token, expected <int> or '(', found on line 0 the word 'U' [2] [2] file: IOstream at line 0. [2] [2] From function operator>>(Istream&, List<T>&) [2] in file /home/mo06811/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/ListIO.C at line 150. [2] FOAM parallel run exiting [2] mpirun: killing job... I can't understand what is going on. Any comment is welcome. |
January 16, 2011, 07:58 |
Hrvoje Jasak
Rep Power: 33 |
Please run it serial - I am investigating a parallel bug here.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 16, 2011, 10:17 |
Masashi Ohbuchi
Rep Power: 17 |
Mr.Jasac, thank you for your quick reply.
I'm really looking forward to new bug fixed release. |
September 23, 2011, 11:17 |
Alistair Everett
Rep Power: 15 |
I'm getting exactly the same error code (although only the first one, not the second), is this due to the same bug? And if so has a fix been issued yet? I'm attempting to run pimpleDyMFoam in parallel using mixerGgiFvMesh, I get the same error with icoDyMFoam, but they both work fine on a single processor. I have tried using different methods for decomposition, all decompose fine with no errors, but kick out the error when I try and run pimpleDyMFoam with them. Regards, Alistair [0] [0] [0] --> FOAM FATAL IO ERROR: [0] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token [0] [0] file: IOstream at line 0. [0] [0] From function IOstream::fatalCheck(const char*) const [0] in file db/IOstreams/IOstreams/IOstream.C at line 109. [0] FOAM parallel run exiting [0] |
September 23, 2011, 11:42 |
Hrvoje Jasak
Rep Power: 33 |
There have been bug fixes here and I'm pretty certain it all works. You may want to try the development line, or wait for the next merge.
Hrv
July 16, 2012, 13:04 |
Similar problem when running transientSimpleDyMFoam with mixerGgiFvMesh in parallel
Arnau
Rep Power: 14 |
I'm experiencing a similar problem when running a case in parallel with OpenFOAM 1.6-ext. I'm using transientSimpleDyMFoam solver with mixerGgiFvMesh dynamic mesh solver on a mesh created with Salome. I want to remark this because I tried even more complex Icem meshes for the same case and everything worked out fine. At first I thought the problem was the Salome mesh, but I had no problem when running serial the same case. This is the output I get right after starting the simulation: Code:
[0] [0] [0] --> FOAM FATAL IO ERROR: [0] error in IOstream "IOstream" for operation operator>>(Istream&, List<T>&) : reading first token [0] [0] file: IOstream at line 0. [0] [0] From function IOstream::fatalCheck(const char*) const [0] in file db/IOstreams/IOstreams/IOstream.C at line 109. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 3123 on node arnau-desktop01 exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- Arnau. |
k-omega-SST model (OF 1.6) - turbulent flat plate | cboss | OpenFOAM Running, Solving & CFD | 25 | August 9, 2016 10:53 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6 | hemph | OpenFOAM | 3 | December 5, 2009 05:19 |
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial | potac | OpenFOAM Installation | 3 | August 27, 2009 10:04 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 10:41 |
