engine simulation with mesh motion and topological changes |
February 15, 2012, 12:31 |
#121 |
Sandeep Menon
Rep Power: 25 |
Isn't dieselEngineFoam obsolete? That's what other forum posts seem to hint at. You might be stuck with a buggy version. You may also want to test out Hrv's branch at 1.6-ext, since he's been making a few changes to the source-tree recently.
You might want to stick to a simple setup before delving into sprays with topo-changes. |
February 15, 2012, 12:54 |
#122 |
Abhishek
Rep Power: 16 |
Ok. I am using OF 1.6-ext and it still has dieselEngineFoam solver. I am using the kind of mesh depicted in the presentations from Prof. Lucchini (Polimi). The part of mesh where spray is injected is kept stationary and spray hasn't penetrated beyond stationary mesh till the solver crash.
April 16, 2012, 10:32 |
#123 |
Abhishek
Rep Power: 16 |
I am trying to use mesquite solver for engine mesh motion. I am getting following error. I downloaded the latest files from git repository https://github.com/smenon/dynamicTopoFvMesh and followed the instructions given in install.txt. Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: mesquiteMotionSolver --> FOAM Warning : From function dlLibraryTable:pen(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file /data1/install/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/dlLibraryTableTemplates.C at line 68 library "libmesquiteMotionSolver.so" did not introduce any new entries Selecting quality metric: InverseMeanRatio Selecting objective function: LPtoP Selecting optimization algorithm: FeasibleNewton Outer termination criterion (tcOuter) was not found. Using default values. Time = -179 --> FOAM FATAL IO ERROR: Unknown patchField type timeVaryingDisplacement for patch type patch Valid patchField types are : 21 ( zeroGradient processor generic global wedge surfaceDisplacement value fixedValue slip empty oscillatingFixedValue mixed calculated angularOscillatingDisplacement oscillatingVelocity symmetryPlane oscillatingDisplacement cyclic angularOscillatingVelocity surfaceSlipDisplacement timeVaryingUniformFixedValue ) file: /data/kur/cfd008/OpenFOAM/RUN/Mesquite/constant/dynamicMeshDict::mesquiteOptions::fixedValuePatche s:iston from line 94 to line 97. From function PointPatchField<PatchField, Mesh, PointPatch, MatrixType, Type>::New(const PointPatch&, const DimensionedField<Type, Mesh>&, const dictionary&) in file /data1/install/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/newPointPatchField.C at line 221. FOAM exiting |
April 16, 2012, 11:49 |
#124 |
Sandeep Menon
Rep Power: 25 |
Make sure that the compiled library "libmesquiteMotionSolver.so" is the updated one from github (which should overwrite the existing version in OF-1.6-ext), because it seems like there's a conflict. Or maybe you have a duplicate libs entry in dynamicMeshDict / controlDict.
The timeVaryingDisplacement pointPatchField is a custom BC that I wrote, which compiles and writes to $FOAM_USER_LIBBIN. You need to add a line like this to system/controlDict: libs ( "libenginePointPatchFields.so" ); |
April 18, 2012, 12:37 |
#125 |
Abhishek
Rep Power: 16 |
Yes. It works perfectly in serial. But it takes a lot of time when I turn on dynamicTopoFvMesh. So, I tried to do it in parallel but having problems with parallel. I could not find parallelDynamicTopoFvMesh on the git hub as reported in earlier posts.
April 18, 2012, 12:47 |
#126 |
Sandeep Menon
Rep Power: 25 |
The version on github should work in parallel. What's the problem exactly?
It would help if you provided more detail - like a stack-trace or a small test-case that can reproduce the problem. |
April 18, 2012, 23:40 |
#127 |
Abhishek
Rep Power: 16 |
Create time
Create dynamic mesh for time = 180 Selecting dynamicFvMesh dynamicTopoFvMesh Selecting metric Knupp Selecting motion solver: mesquiteMotionSolver --> FOAM Warning : From function dlLibraryTable:pen(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file /opt/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/dlLibraryTableTemplates.C at line 68 library "libmesquiteMotionSolver.so" did not introduce any new entries Selecting quality metric: InverseMeanRatio Selecting objective function: LPtoP Selecting optimization algorithm: FeasibleNewton Outer termination criterion (tcOuter) was not found. Using default values. Time = 180.25 Solving for point motion: Initial residual: 1 Final residual: 0.0094732 No Iterations: 29 Solving for point motion: Initial residual: 1 Final residual: 0.009793 No Iterations: 55 ~~~ Mesh Quality Statistics ~~~ Min: 0.313026 Max: 0.998508 Mean: 0.843209 Cells: 95154 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [0] finement Progress: 82.3878% : Bisections: 1674, Collapses: 0, Total: 1674 [0] [0] --> FOAM FATAL ERROR: [0] [0] FOAM parallel run aborting [0] [0] Failed to match edge: 24274 :: (4349 627) using comparison edge: (2194 70)-------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 28484 on node cfd011 exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- |
April 19, 2012, 00:11 |
#128 |
Sandeep Menon
Rep Power: 25 |
Can I get my hands on a test-case? Preferably on a time-step where I can reproduce the problem...
April 19, 2012, 09:37 |
#129 |
Abhishek
Rep Power: 16 |
I have attached the simple cylinder case. Geometry is given as .geo file (gmsh format) due to upload size limitation. |
April 19, 2012, 09:48 |
#130 |
Sandeep Menon
Rep Power: 25 |
I'm not really sure how to get a mesh out of the geometry file you've given me. Care to give a few tips?
April 19, 2012, 11:20 |
#131 |
Abhishek
Rep Power: 16 |
Sorry for that. I have sent you the whole setup with mesh in openFoam format on your gmail. |
April 19, 2012, 11:36 |
#132 |
Sandeep Menon
Rep Power: 25 |
Thanks for that. I was able to reproduce the problem, and I'll get back once I have a fix (and some time on my hands).
September 23, 2012, 05:59 |
#133 |
Sasan Ghomi
Rep Power: 15 |
Hi abminternet
I am running this case (simpleEngineStem) but I have an error..please help me ERROR: In /home/sasan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.12.0/VTK/Filtering/vtkExecutive.cxx, line 756 vtkPVCompositeDataPipeline (0x1ffe600): Algorithm vtkPOpenFOAMReader(0x1e37230) returned failure for request: vtkInformation (0x2a41ed0) Debug: Off Modified Time: 362516 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 Last edited by sasanghomi; September 27, 2012 at 16:52. |
October 18, 2012, 00:19 |
#134 |
Anthony Nitski
Rep Power: 17 |
Hi foamers!
Someone can write the guide step by step for perfoming calculation of diesel. (Read 7 pages of posts. But still didn't get it.) 1) combustion chamber without valves with moving piston. Cyclic BC or full 3D model. 2) diesel spray, evaporation 3) combustion Which solvers should use? Which version of OF (1.6 ext, 2.1) ? Which dynamic mesh library should use? Which tutorial cases should use for startup? Or some working cases... Is it works in mpi parallel? something like that http://files.nequam.se/scania_movie.gif and http://www.foamcfd.org/Nabla/main/spray.html#spray |
October 18, 2012, 07:58 |
Hi
#135 |
Sasan Ghomi
Rep Power: 15 |
I think best solver is sonicTurbDyMEngineFoam . It is available in OP-ext 1.6
I couldn't run it with mpirun. sasan. |
November 16, 2012, 01:23 |
#136 |
Anthony Nitski
Rep Power: 17 |
So, i have searched forum and now i guess that for OpenFOAM 2.1.1 correct solver for diesel engine is sprayEngineFoam. Correct me please, if i wrong. But for this solver there is no tutorial case. Does anybody have working case for this solver? Share it please..
November 19, 2012, 00:21 |
dieselEngineFoam tutorial for 1.6-ext
#137 |
Anthony Nitski
Rep Power: 17 |
So, a tutorial case for dieselEngineFoam had to do it myself. I took the Niklas Nordin case (http://files.nequam.se/dieselEngineFoam_scania.tgz) and modify it for 1.6-ext. Here is (without mesh and initial U field, use it from original)
November 19, 2012, 00:31 |
#138 |
Anthony Nitski
Rep Power: 17 |
January 23, 2013, 08:49 |
#139 |
Sasan Ghomi
Rep Power: 15 |
yes,It's a solver for cold flow and It does not support combustion...
January 23, 2013, 09:11 |
#140 |
Sasan Ghomi
Rep Power: 15 |
Hi peter
I have a question about simpleEngineStem.tar.gz case...this case uses PISO method and have relaxation factors....I think the results are not correct...please correct me...is my idea wrong? |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam-solving/83177-engine-simulation-mesh-motion-topological-changes.html
Posted By | For | Type | Date | |
Untitled document | This thread | Refback | February 4, 2014 12:36 |
Dynamic moving mesh | Pei-Ying Hsieh (Hsieh) | OpenFOAM Running, Solving & CFD | 64 | June 7, 2012 11:04 |
engine simulation with mesh motion and topological changes | abminternet | OpenFOAM | 0 | December 16, 2010 12:47 |
[Commercial meshers] Good mesh for pistoncylinder application | Serkan Cetin | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2010 08:36 |
Radiation and miscellaneous enhancements | vtk_fan | OpenFOAM Running, Solving & CFD | 6 | February 18, 2008 00:49 |
Valve action | Hrvoje Jasak (Hjasak) | OpenFOAM Running, Solving & CFD | 0 | January 13, 2005 14:23 |
