Unexpected large decrease in Total temperature across the shock using sonicFoam
Old   December 15, 2010, 06:47
Question Unexpected large decrease in Total temperature across the shock using sonicFoam
Nishit Joseph
JLight is on a distinguished road
Hi OpenFOAM users!
The past week I have been looking into the possibility to use sonicFoam for some of my Uni work but have been I am experiencing some issues.
Using the tutorial:
..\tutorials\compressible\sonicFoam\laminar\forwar dStep
For the given case of Ma=3, it was noted that the total temperature seen in ParaView using the Filters->Data Analysis->Calculator and creating a field using this formula
T0 = T + (mag(U))^2 / (2* cp)
Where cp was obtained using data from the thermophysicalProperties file.
There is a significant drop in total temperature across the shock. Also the recovery temperature is also significantly lower then what I would expect.
Can anyone can point out what I am doing wrong?
I do not have this issue if I use the older (no longer part of the official source) rhoSonicFoam - this solver uses defined thermodynamic properties for cp and R. The solver rhoSonicFoam is not attractive to me as I want to use the ePsiThermo Model.
Cheers!
Nishit
JLight is offline   Reply With Quote
how to define the backflow total temperature hanjun FLUENT 4 July 17, 2014 05:00
Total Temperature in a Rotating Frame Paul Lewis CFX 1 September 14, 2005 15:47
The static temperature is higher than total temp devy FLUENT 0 March 27, 2003 21:16
Help! Coupled Vs Implicit - Total temperature sile FLUENT 3 March 10, 2003 16:58
Total pressure and temperature, isentropic Chris FLUENT 0 January 16, 2003 06:30
