Improved implementation of dynamic Smagorinsky |
May 2, 2016, 14:28 |
#81 |
Pavan
Rep Power: 10 |
Dear Alberto
http://www.cfd-online.com/Forums/members/alberto.html I was wondering the reason for selecting the ce value in you dynamic Smagorinsky library. I am new to OpenFOAM, what is ce and what is the reason for specifying that particular value to it? |
June 16, 2016, 12:31 |
#82 | |
Ehsan Asgari
Rep Power: 18 |
Would you please point out that where "D" is defined in the code?! Thanks Syavash |
December 21, 2016, 03:29 |
#83 |
mohafarmani
Rep Power: 11 |
Dear Alberto,
i want to use dynamicsmagorinsky code that you have generously contributed, but as i use your instructions (wmake libso) in openFoam3.01 the error is appeared: wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file dynamicSmagorinsky.C could not open file Smagorinsky.H for source file dynamicSmagorinsky.C due to No such file or directory could not open file LESfilter.H for source file dynamicSmagorinsky.C due to No such file or directory g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/turbulenceModels -I/opt/openfoam30/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam30/src/turbulenceModels/LES/LESfilters/lnInclude -I/opt/openfoam30/src/turbulenceModels/incompressible/LES/lnInclude -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c dynamicSmagorinsky.C -o Make/linux64GccDPInt32Opt/dynamicSmagorinsky.o In file included from dynamicSmagorinsky.C:25:0: dynamicSmagorinsky.H:85:25: fatal error: Smagorinsky.H: No such file or directory compilation terminated. /opt/openfoam30/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/dynamicSmagorinsky.o' failed make: *** [Make/linux64GccDPInt32Opt/dynamicSmagorinsky.o] Error 1 could you please help me to use the model properly? Regards Mohammad |
February 6, 2017, 05:52 |
#84 |
Lorenzo
Rep Power: 11 |
February 22, 2017, 04:58 |
#85 |
Bo Kong
Rep Power: 10 |
Has anyone compiled this code in version 4.0 and shared for me? I fail to do this .
Yours, Bo Kong |
February 22, 2017, 20:17 |
#86 |
Lorenzo
Rep Power: 11 |
Compiling procedure between OF 4.0 and previous versions are quite different. Try switching back to OF 2.4.0 for instance. I compiled Alberto's model with success on such this version
November 6, 2017, 08:36 |
#87 |
Yeru
Rep Power: 12 |
Hi Alberto,Thank you very much for sharing the model.
I just read your code and compared with homogeneousDynSmagorinsky in OF230. I got some questions hope to get answer from you: 1. Do you achieve the locally averaging by adding the class "fvc" in front of the function, if yes, can you explain a little bit more why is that? 2. In the code "nuSgs_ = max(cD(D)*sqr(delta())*sqrt(magSqr(D)), -nu());", why you use "-nu()" rather than 0? If cD(D)*sqr(delta())*sqrt(magSqr(D)) < -nu() and -nu() should be a negative value anywhere, this will produce a negative nuSgs value. Am I right? Kind regards, Yeru |
August 29, 2018, 05:04 |
#88 |
Ehsan Asgari
Rep Power: 18 |
For All those who miss dynamicSmagorinsky model on new versions of OpenFOAM,
I have developed and compiled the code for version 4.1. You can find the code at the following link: https://github.com/syavash20/TurbLab...magorinsky_4.1 Also, a channel395 example has been provided to test the implementation. Enjoy, Syavash |
August 29, 2018, 09:35 |
OpenFOAM3
#89 | |
Nima Samkhaniani
Rep Power: 25 |
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
December 20, 2018, 06:07 |
#90 |
Cyrille Bonamy
Rep Power: 11 |
For info the 4.1 version can be used with the versions 5.0 and 1806
February 5, 2019, 11:35 |
Usage of dynamicSmagorinsky
#91 |
Jo Mar
Rep Power: 11 |
I am a bit confused that the during a simulation no output about bounding k is written to the log, as it was done in previous versions of this turbulence model (OF231).
Can anybody confirm this? Or am I doing something plainly wrong? Or was this taken out of the code? I am doing a pimpleFoam simulation with a custom solver with the setup of turbulenceProperties as suggested by the creators, https://github.com/syavash20/TurbLab...magorinsky_4.1 Thanks a lot in advance to anybody clarifying this for me. Best wishes Edit: I am using OF1812+ Last edited by KingKraut; February 5, 2019 at 11:36. Reason: I am using Vs OF1812+ |
February 7, 2019, 03:17 |
#92 | |
Ehsan Asgari
Rep Power: 18 |
AFAIK, k is bounded only when its value is smaller than SMALL=1e-20, otherwise its minimum value would be read from the field. But in general, bounding k to a minimum value should not affect the solution procedure as k is an independent quantity. It is considered in the SGS stress tensor only. It will become more noticeable if you would like to calculate the ratio of resolved to total turbulent kinetic energy. Regards, Syavash |
February 13, 2019, 10:18 |
#93 |
Jo Mar
Rep Power: 11 |
Dear syavash,
thanks a lot for the fast reply. So I understand correctly that no output from bounding k is written since this is simply not applicable? By the way thanks again for this implementation of dynamic smagorinsky for the versions OF4 and upwards. The results are practically identical to my previous simulations with OF231. Best wishes Johannes |
February 13, 2019, 18:19 |
#94 | |
Santiago Lopez Castano
Rep Power: 16 |
February 14, 2019, 06:45 |
#95 | |
Ehsan Asgari
Rep Power: 18 |
You're welcome. You don't see the output since the function "bound" is not used anymore. Best Regards, Syavash |
July 18, 2019, 07:49 |
#96 |
Adam
Rep Power: 7 |
Could somebody please explain what I have to change if I want to use it with a compressible solver. I tried to compare the Smagorinsky model to see what to change but if I start it still tells me the dynamic model is not available.
I want to use the version of syavash: https://github.com/syavash20/TurbLab Thanks in advance |
July 18, 2019, 09:24 |
#97 | |
Adam
Rep Power: 7 |
I had to change the makeTurbulence.C to this Code:
// Copyright held by original authors #include "CompressibleTurbulenceModel.H" #include "compressibleTransportModel.H" #include "fluidThermo.H" #include "addToRunTimeSelectionTable.H" #include "makeTurbulenceModel.H" #include "ThermalDiffusivity.H" #include "EddyDiffusivity.H" #include "LESModel.H" #define makeLESModel(Type) \ makeTemplatedTurbulenceModel \ (fluidThermoCompressibleTurbulenceModel, LES, Type) namespace Foam { typedef ThermalDiffusivity<CompressibleTurbulenceModel<fluidThermo> > fluidThermoCompressibleTurbulenceModel; typedef LESModel<EddyDiffusivity<fluidThermoCompressibleTurbulenceModel> > LESfluidThermoCompressibleTurbulenceModel; } #include "dynamicSmagorinsky.H" makeLESModel(dynamicSmagorinsky); and the Make file to this Code:
EXE_INC = \ -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \ -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \ -I$(LIB_SRC)/transportModels/compressible/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/solidThermo/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/solidSpecie/lnInclude \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ LIB_LIBS = \ -lcompressibleTransportModels \ -lfluidThermophysicalModels \ -lsolidThermo \ -lsolidSpecie \ -lturbulenceModels \ -lspecie \ -lfiniteVolume \ -lmeshTools my mistake was a missing LIB but with this changes it works |
December 4, 2020, 10:41 |
#98 |
Tian Jin
Rep Power: 6 |
Hello.
I want to employ the dynamic procedure on the scalar flux, but I don't know if we can get dynamic diffusivity or Schmidt number in the dynamic Smagorinsky model. Is there anyone doing this before? For now, I use the dynamic Smagorinsky model for the flow, but for the scalar transport, I use the function scalartransport in OpenFOAM, they need alpha_t and alpha, and this is the constant value, I want to use dynamic diffusivity/Schmidt number in the scalar transport equation. Does anyone have the good idea? |
December 5, 2020, 05:10 |
#99 | |
Rep Power: 16 |
https://www.mdpi.com/2311-5521/4/3/171 |
December 5, 2020, 18:09 |
#100 | |
Tian Jin
Rep Power: 6 |
I am a beginner and I don't know how to translate your formula to OpenFOAM code. Would you be kind enough to share with me your OpenFOAM code about the dynamic scalar flux? |
Smagorinsky Dynamic Cosant in UDF | Paolo Lampitella | FLUENT | 1 | June 17, 2009 04:40 |
Dynamic Smagorinsky LES | Lourival | FLUENT | 0 | April 14, 2006 14:48 |
Dynamic Smagorinsky Model | Andrew | Main CFD Forum | 1 | November 30, 2004 01:52 |
Reply to Tim Re Dynamic Smagorinsky model | Ajay S. Parihar | Main CFD Forum | 9 | June 2, 2002 17:24 |
Dynamic Smagorinsky model | Tim | Main CFD Forum | 7 | May 29, 2002 08:37 |
