Improved implementation of dynamic Smagorinsky
Like Tree38Likes
Old   May 4, 2013, 13:03
Alberto Passalacqua
A quick checklist:
- Did the code compile successfully?
- Can you run the test case provided with the code?
Best,
Alberto Passalacqua
Old   May 4, 2013, 15:07
Bobby
babakflame is on a distinguished road
Dear Alberto
Hi
- the code compiled successfully.
- I executed the test case, it works successfully
My openFoam is 2.1.x . Is it from my openFoam version?
I have still the problem in reactingFoam case::
Selecting turbulence model type LESModel
Selecting LES turbulence model dynamicSmagorinsky
--> FOAM FATAL ERROR:
Unknown LESModel type dynamicSmagorinsky
Valid LESModel types:
6
DeardorffDiffStress
Smagorinsky
SpalartAllmaras
homogeneousDynOneEqEddy
lowReOneEqEddy
oneEqEddy
    From function LESModel::New(const volScalarField&, const volVectorField&, const surfaceScalarField&, const basicThermo&, const word&)
    in file LESModel/LESModel.C at line 140.
FOAM exiting
Regards
Bobi
babakflame is offline   Reply With Quote
Old   May 5, 2013, 01:52
Alberto Passalacqua
The code I wrote is for incompressible flow solvers, and it is added to the library of incompressible LES models. The reactingFoam solver is compressible, and uses the compressible LES models.
Best,
songwukong and wenxu like this.
Alberto Passalacqua
Old   May 5, 2013, 09:41
Bobby
Hi Alberto
I think that reactingFoam is incompressibe, cause we have another solver called rhoReactingFoam which is compressible.
Don't you think am I right?
Regards
Bobi
Old   May 5, 2013, 13:43
Alberto Passalacqua
Hi Alberto
Regards
Bobi
Looking at the code of the two solvers, they are both compressible, but they use different packages for the thermodynamic properties (see comments in the code).
babakflame likes this.
Alberto Passalacqua
Old   July 25, 2013, 10:50
Default Problem with Time Writing of Directories when running in Parallel
  #66
Krishna
rkc.cfd is on a distinguished road
Hi Alberto,
I was able to compile dynamicSmagorinsky model from your GIT repository and ran a test case on 2D flow over cylinder problem and had no problems.
I have a current 3D case running fine with regular Smagorinsky model running in parallel with pisoFoam. I just changed Smagorinsky model to dynamicSmagorinsky and it is running good but not writing the data out or even making time directories in processor folders. Could you suggest me path to debug this problem. My current version of OpenFOAM is 2.2.x compiled from source.
Cheers
rkc.cfd is offline   Reply With Quote
Old   November 13, 2013, 12:32
Default Turbulent Prandtl number?
  #67
David Van Cauwenberge
dvcauwe is on a distinguished road
Hi Alberto,
First of all I'd like to thank you for making your code accessible. Compilation ran without problems and our results so far are significantly better than using traditional Smagorinsky or the homogenous version.
I was just wondering if you had ever tried to implement Eq. 17 for the Eddy Prandtl number in the Lilly (1992) modification? I used the method described here, applying cell-face averaging like in your method but unfortunately the values for the Prandtl number are very unstable.
Could you recommend other averaging/limiting methods that might allow more stable computation? Or does anyone else know of articles that may refer me to a practical implementation of a variable subgrid Prandtl/Schmidt number?
Thank you very much in advance.
Best regards,
David
dvcauwe is offline   Reply With Quote
Old   December 24, 2013, 03:08
Peter
palmerlee is on a distinguished road
Originally Posted by feldy77 View Post
Dear Alberto,
Thank you very much for your contribution. I tried to use your model with buoyantBoussinesqPimleFoam. The compilation process was completed successfully. Then I modified LESProperties and controlDictionary files according to your instructions. Unfortunately something screws up when I try to run the simulation. I am getting the following warning:
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName& functionLibName)
in file db/dlLibraryTable/dlLibraryTable.C at line 78
could not load /home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libdynLocalAverageSmagorinskyModel.so: undefined symbol: _ZNK4Foam14incompressible9LESModels11GenEddyVisc1B Ev
Do you have any idea what can be the problem?
Thank you very much, Yuri
Dear Yuri
I am trying to use buoyantBoussinesqPimleFoam with LES too. I noticed that this solver only works with RANS. I want to know whether or not your simulation succeed to give good results so that I can use this solver with LES confidently.
Thank you!
palmerlee
palmerlee is offline   Reply With Quote
Old   February 24, 2014, 17:33
Default dynamicSmagorinskyModel.so
  #69
aylalisa is on a distinguished road
Dear Alberto,
I am happy that u've published dynamicSmagorinskyModel including its actual advantage!
I've run computation with your model.
Though after I've start blockMesh I've received following FOAM Warning :
--> FOAM Warning :
    From function dlOpen(const fileName&, const bool)
    in file POSIX.C at line 1179
    dlopen error : /home/lisa/OpenFOAM/lisa-2.2.2/platforms/linux64GccDPOpt/lib/libdynamicSmagorinskyModel.so: undefined symbol: _ZTIN4Foam14incompressible9LESModels11GenEddyViscE
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
    could not load "libdynamicSmagorinskyModel.so"
Could you comment that warning?
Thank you!
regards,
Aylalisa
aylalisa is offline   Reply With Quote
Old   February 25, 2014, 07:31
Sorry, found the answer....very long thread!
Old   April 1, 2014, 09:17
vut
vut is on a distinguished road
Dear Alberto,
I would like to implement your model for my study case.
I downloaded the folder "dynLocalAverageSmagorinsky" from your website and I do "wmake libso".
Then I added
in controlDict
libs ( "libOpenFOAM.so" "libdynLocalAverageSmagorinskyModel.so" ) ;
and in LESProperties:
LESModel dynLocalAverageSmagorinsky; delta cubeRootVol;
dynLocalAverageSmagorinskyCoeffs { filter simple; ce 1.048; }
But it didn't work. I had some warnings as shown below:
Create time
--> FOAM Warning :
dlopen error : libdynLocalAverageSmagorinskyModel.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
could not load "libdynLocalAverageSmagorinskyModel.so"
Create mesh for time = 0
Additionally, when I compile your model typing wmake libso, I obtained:
SOURCE=dynLocalAverageSmagorinsky.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/turbulenceModels -I/opt/openfoam230/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam230/src/turbulenceModels/LES/LESfilters/lnInclude -I/opt/openfoam230/src/turbulenceModels/incompressible/LES/lnInclude -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/dynLocalAverageSmagorinsky.o
I am waiting to hear from you...
Thanks in advance,
vut
vut is offline   Reply With Quote
Old   April 1, 2014, 14:51
Alberto Passalacqua
The problem is that the library containing the model cannot be found, as the solver tells you:
Originally Posted by vut View Post
--> FOAM Warning :
--> FOAM Warning :
You should check where the library is written, and verify that location is accessible.
Note that the code only works with OF 2.0.x. It wasn't tested with recent versions.
Alberto Passalacqua
Old   April 1, 2014, 17:14
Alberto Passalacqua
I have updated the tutorial to work with 2.3.x (based on the pimpleFoam/channel395 tutorial). The code did not require any change. You find the updated code here:
https://bitbucket.org/albertop/dynamicsmagorinsky
Alberto Passalacqua
Old   April 2, 2014, 09:12
vut
Dear Alberto,
Thanks for your generous share.
Actually, I recently tried your sub-grid scale model (last version) and it worked despite of mentioned warnings.
You mentioned that the code was not changed and the test case was modified solely, right? Please confirm because it seems interesting to implemented in my case study:
- your sub-grid scale model
- and homogeneousDynSmagorinsky model available now in OF 2.3.0
and compare them.
Best regards,
vut
Old   April 2, 2014, 09:44
vut
An other question:
Does your model correspond to an article?
Ghosal et al. 1995 ("A dynamic localization model for LES of turbulent flows" in J. Fluid Mech. vol. 286, pp. 229-255)
or
Lilly et al. 1992 ("A proposed modification of the Germano subgrid-scale closure method")
Thanks in advance,
vut
aylalisa likes this.
Old   April 5, 2014, 07:01
vut
It sound like the dynamic Smagorinsky developed by Alberto might have been followed the article of Lilly 1992.
He repeated many times that a local average over faces of cell is implemented instead of an average over the entire computational domain.
Have a nice weekend,
vut
Old   April 17, 2014, 23:55
sqing
Sunxing is on a distinguished road
Dear Alberto,
Can I use this model in OF 2.1.1?
Best regards.
xing
Sunxing is offline   Reply With Quote
Old   June 9, 2014, 04:49
Huang Xianbei
huangxianbei is on a distinguished road
Hi,alberto:
I have a question about the MM definition in volScalarField dynamicSmagorinsky::cD
As Lily stated, MM=filter(delta)^2*filter(S_bar)*filter(D)-(delta)^2*filter(S_bar*D)
D=symm(grad(U))=Sij
in the dynamicSmagorinsky.C
MM=sqr(delta())*(filter_(mag(D)*(D)) - 4*mag(filter_(D))*filter_(D))
So filter(delta)/delta=2 is used
However, mag(D) returns (SijSij)^1/2 instead of (2SijSij)^1/2=S_bar
as a result,
MM=MM_exact/(2^1/2)
Thus
cD=cD_exact*2^1/2
Above, _exact represents the exact value in Lily's method
If it's my misunderstanding, please correct me.
Best reguards
Xianbei
huangxianbei is offline   Reply With Quote
Old   August 22, 2014, 10:16
alp albayrak
alpalbayrak is on a distinguished road
Hi Alberto,
Maybe a recurring question, but;
I would like to know why you defined the k field. You could easily avoid the field declaration (B.C conditions etc.) and define it like the objects (cI,cD). Does it really have a hidden reason to declare it as field?
Regards
Alp
alpalbayrak is offline   Reply With Quote
Old   January 12, 2015, 10:40
Laurent Schindfessel
LSchind is on a distinguished road
Dear all,
I’ve used the dynamic Smagorinsky model in a large-eddy simulation of a confluence, but I am facing rather negative nuSgs near the walls. I know that there is a physical explanation for negative nuSgs, but in my simulations there is a very large region where nuSgs equals -1E-6 (i.e. minus the fluid viscosity) persistently. Therefore, I don’t think my results are correct.
Because I notice these negative values mainly in the first two cells near the wall, I think the problem is related to how I treat the walls. I should mention that due to computational resources, the wall is not resolved, but rather modeled by means of a wall function (namely nutURoughWallFunction). If I refine near the wall, the region of nuSgs persistently equaling -1E-6 decreases. However, I have only tried limited refinement, as I want to limit the computational costs.
Therefore, the question I want to ask is: do you think this dynamic model is compatible with using wall functions? Is it possible that the calculation of nuSgs by the dynamic Smagorinsky model conflicts with the calculation of nuSgs by the wall function?
Or more in general: does anyone have experience with the combined use of this model and wall functions?
Thanks in advance,
Laurent
LSchind is offline   Reply With Quote
Smagorinsky Dynamic Cosant in UDF Paolo Lampitella FLUENT 1 June 17, 2009 04:40
Dynamic Smagorinsky LES Lourival FLUENT 0 April 14, 2006 14:48
Dynamic Smagorinsky Model Andrew Main CFD Forum 1 November 30, 2004 01:52
Reply to Tim Re Dynamic Smagorinsky model Ajay S. Parihar Main CFD Forum 9 June 2, 2002 17:24
Dynamic Smagorinsky model Tim Main CFD Forum 7 May 29, 2002 08:37
