Improved implementation of dynamic Smagorinsky
Like Tree38Likes
Old   July 15, 2011, 10:51
Perry L. Johnson
PerryLJohnson is on a distinguished road
Alberto,
Sorry to bug you some more on this code. I was revisiting your code, and it seems to me you have left out two coefficients in your MM equation (Germano et al. Eq 15, right hand side): the 2 out in front and the sqrt(2) in the | Sij | = sqrt (2 * Sij * Sij).
volSymmTensorField MM =
sqr(delta())*(filter_(mag(D)*(D)) - 4*mag(filter_(D))*filter_(D));
But I also see that the sqrt(2) is cancelled out in the definition of nuSgs because it is not included there either.
nuSgs_ = max(cD(D)*sqr(delta())*sqrt(magSqr(D)), -nu());
The leading coefficient of 2 (coming from tau_ij = 2 * nu_eff * S_ij) does not appear to cancel out since the definition of the effective stress is higher up in the turbulence model code.
00096 tmp<fvVectorMatrix> GenEddyVisc::divDevBeff(volVectorField& U) const
00097 {
00098 return
00099 (
00100 - fvm::laplacian(nuEff(), U) - fvc::div(nuEff()*dev(T(fvc::grad(U))))
00101 );
00102 }
So it seems to me there should be something to the effect of
MM *= 2;
directly after your definition of the MM tensor.
Please correct me if I am missing something here.
Regards,
Perry
PerryLJohnson is offline   Reply With Quote
Old   July 15, 2011, 13:07
Alberto Passalacqua
Hi, my code is entirely based on what OF calls "homogeneousDynSmagorinsky" model. I think the reference is not Germano et al. but Lilly (1992) "A proposed modification of the Germano subgrid-scale closure method".
If there is a bug in the original code, then there is a bug in mine too :-D. I will check into that as soon as I can.
Alberto Passalacqua
Old   July 18, 2011, 03:39
Bernhard
Bernhard is on a distinguished road
I also have the impression there is something wrong with the definition of MM, see this post: http://www.cfd-online.com/Forums/ope...details-2.html But if you can point me at my mistake there you're very welcome
@alberto: In the Lilly formulation c(D) is devided by two (Cs=LM/(2*M*M)), which is not incorporated here, so if you apply his suggestion, MM *= 2, then you would end up with exactly that right?
shuige likes this.
Bernhard is offline   Reply With Quote
Old   July 18, 2011, 04:39
Alberto Passalacqua
I am sorry, I pointed to the wrong reference in my last post. The implementation of LES models in OpenFOAM is based on:
C. Fureby, G. Tabor, H. G. Weller, and A. D. Gosman, A comparative study of subgrid scale models in homogeneous isotropic turbulence, Phys. Fluids 9, 1416 (1997); doi:10.1063/1.869254
According to this work:
k_sgs = c_I*(delta*|D|)^2
nu_sgs = c_D*(delta^2)*|D|
In the dynamic approach, they define:
c_I = <0.5 tr(L) m>/<mm>
c_D = <L_D M>/<M M>
with L_D, m and M defined as a function of D, in a way that seems consistent to me (please, check, I went through it quickly) with the OF implementation.
Alberto Passalacqua
Old   July 18, 2011, 11:56
Perry L. Johnson
I am in agreement with Bernhard. In Lilly's paper, the coefficient '2' in equation 8 (Fureby equation 6) becomes manifest in the coefficient '1/2' in equation 11. It seems to mysteriously vanish in Fureby's derivation, however, in his equation 7.
Old   July 18, 2011, 12:08
Alberto Passalacqua
Hi, I agree. However, since the problem also affects homogeneousDynSmagorinsky, I think you should report it on OpenCFD bug tracker. This might provide an explanation too.
Best,
Alberto Passalacqua
Old   July 18, 2011, 15:00
Perry L. Johnson
I put in a bug report, we'll see if an explanation is forthcoming.
Old   July 23, 2011, 15:13
Alberto Passalacqua
Bug corrected upstream, and fix merged in my modified version. You can download it from the usual git repository ( https://github.com/AlbertoPa/dynamicSmagorinsky ).
Thanks for pointing this out.
Best,
Alberto Passalacqua
Old   August 9, 2011, 04:42
Nico T
deniggo is on a distinguished road
Alberto, thanks for providing the code. I compiled it in OF 2.0 and changed input-files as described in readme.
My case works but it stays laminar, while in the standard Smagorinsky with constant coefficients turbulence is developed. I use pisoFoam and pimpleFoam. Did I forget something to change or is the model not applicable to piso/pimpleFoam?
Thanks for your help!
Nico
deniggo is offline   Reply With Quote
Old   August 9, 2011, 11:04
Alberto Passalacqua
Hi, depending on your case you need to initialise the simulation with a perturbed field to favour the development of the turbulent structures. There are is a tool in the forum for channel flows (perturbU) and probably some user adapted it to pipe flows too.
Best,
Alberto Passalacqua
Old   January 5, 2012, 03:58
M.H.Arabnezhad
engma3 is on a distinguished road
Hi alberto,
Thanks for providing the code. I use your code for simulation of a swirl jet. The problem is in calculation of kinetic energy , It gives me negative values.
Thanks,
engma3
engma3 is offline   Reply With Quote
Old   January 5, 2012, 11:25
Alberto Passalacqua
The value should be bounded to kMin_.
Best,
Alberto Passalacqua
Old   February 7, 2012, 15:28
Default Problems with trying the model
  #53
Yuri Feldman
feldy77 is on a distinguished road
Dear Alberto,
Thank you very much for your contribution. I tried to use your model with buoyantBoussinesqPimleFoam. The compilation process was completed successfully. Then I modified LESProperties and controlDictionary files according to your instructions. Unfortunately something screws up when I try to run the simulation. I am getting the following warning:
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName& functionLibName)
in file db/dlLibraryTable/dlLibraryTable.C at line 78
could not load /home/yurifeld/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libdynLocalAverageSmagorinskyModel.so: undefined symbol: _ZNK4Foam14incompressible9LESModels11GenEddyVisc1B Ev
Do you have any idea what can be the problem?
Thank you very much, Yuri
feldy77 is offline   Reply With Quote
Old   February 7, 2012, 20:05
Perry L. Johnson
Originally Posted by feldy77 View Post
Dear Alberto,
--> FOAM Warning :
Yuri,
You should be able to safely ignore this warning, see post #21.
Perry
Old   February 7, 2012, 21:49
Alberto Passalacqua
Yes, Perry is right :-)
Btw, you could also consider the langrangianDynSmagorinsky model in OpenFOAM 2.x, which is based on a more rigorous treatment of the dynamic coefficient.
Best,
Alberto Passalacqua
Old   April 8, 2012, 18:29
Alberto Passalacqua
For your information, I moved my repository to bitbucket, so future versions will be here:
https://bitbucket.org/albertop/dynamicsmagorinsky
Alberto Passalacqua
Old   March 27, 2013, 17:29
ehk
ehsankf is on a distinguished road
Dear Alberto,
I would like to know if this new dynamic smagorinsky model could be changed to do averaging in homogenous direction ( not whole domain) in case of channel flow .
Thanks in advance
ehsankf is offline   Reply With Quote
Old   May 3, 2013, 12:43
Bobby
babakflame is on a distinguished road
Dear Alberto
I am trying to include dynamicSmagorinsky SGS model for reactingFoam solver, I did exactly as u have said in
However, When I executed the file; I got this error:
Selecting LES turbulence model dynamicSmagorinsky
--> FOAM FATAL ERROR:
Unknown LESModel type dynamicSmagorinsky
Valid LESModel types:
6
DeardorffDiffStress
Smagorinsky
SpalartAllmaras
homogeneousDynOneEqEddy
lowReOneEqEddy
oneEqEddy
    From function LESModel::New(const volScalarField&, const volVectorField&, const surfaceScalarField&, const basicThermo&, const word&)
    in file LESModel/LESModel.C at line 140.
FOAM exiting
It seems that the code has not recognized dynamicSmagorinsky.H & .C files.
I should note that I have put the dynamicSmagorinsky folder in My home directory and not in OpenFOAM sources, My openFOAM version is 2.1.x
Would You PLZ help me?
Any hint is appreciated
Best Regards
Bobi
babakflame is offline   Reply With Quote
Old   May 3, 2013, 12:50
ehk
you should include the new model in controlDict.
Old   May 3, 2013, 13:09
Bobby
Dear Ehsan
Hi
I have included this line at the end of controldict file:
libs ( "libOpenFOAM.so" "libdynamicSmagorinskyModel.so" ) ;
However, The problem is still apparent
Bobi
Smagorinsky Dynamic Cosant in UDF Paolo Lampitella FLUENT 1 June 17, 2009 04:40
Dynamic Smagorinsky LES Lourival FLUENT 0 April 14, 2006 14:48
Dynamic Smagorinsky Model Andrew Main CFD Forum 1 November 30, 2004 01:52
Reply to Tim Re Dynamic Smagorinsky model Ajay S. Parihar Main CFD Forum 9 June 2, 2002 17:24
Dynamic Smagorinsky model Tim Main CFD Forum 7 May 29, 2002 08:37
