Improved implementation of dynamic Smagorinsky
Like Tree38Likes
Old   January 23, 2011, 05:42
Default Warning
  #21
Yashar Afarin
yashar.afarin is on a distinguished road
Send a message via Skype™ to yashar.afarin
Hi Alberto,
thanks for sharing your corrected dynamicSmagorinsky. I have complied it without any problem. but when I want to decompose my mesh, the below warning wolud be appear( I am using OF-1.6.x and Fedora-12):
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName& functionLibName)
in file db/dlLibraryTable/dlLibraryTable.C at line 79
could not load /home/Yashar/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libdynamicSmagorinskyModel.so: undefined symbol: _ZNK4Foam14incompressible9LESModels
I would appreciate if you could help me to solve it.
yashar.afarin is offline   Reply With Quote
Old   January 23, 2011, 14:11
Alberto Passalacqua
Hi Yashfar,
nothing to worry about. You can safely ignore the warning. It happens sometime when using libraries through controlDict.
Best,
Alberto Passalacqua
Old   January 29, 2011, 13:11
Yashar Afarin
Originally Posted by alberto View Post
Hi Yashfar,
Best,
Hi Alberto,
thanks for your reply and your sharing.
sincerely yours.
Old   February 9, 2011, 05:17
Yashar Afarin
Hi Alberto,
I would appreciate if you could answer me that " how could this model be used in compressible solver?"
Best regard,
Old   February 9, 2011, 05:22
Alberto Passalacqua
Hi Yashar,
it cannot. The implementation I released works for incompressible solvers. For the compressible version you need to implement a compressible dynamic Smagorinsky model (see for example Piomelli's papers to have an idea).
Best,
Alberto Passalacqua
Old   February 17, 2011, 09:16
Default non-root compilation of dynamicSmagorinsky
  #26
Bernhard Grieser
BernhardGrieser is on a distinguished road
Alberto,
thank you very much for your efforts on implementing a truly dynamic Smagorinsky model! I realized the flaw of the old implementation a few weeks ago and I am more than happy that someone already took care of the issue.
I'm running my simulations as a non-root user on my university's HP XC3000, where OpenFOAM 1.7 is pre-installed.
Logically it produces an error when compiling with wmake libso:
/usr/bin/ld: cannot open output file /software/all/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libdynamicSmagorinskyModel.so: Permission denied
collect2: ld returned 1 exit status
make: *** [/software/all/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libdynamicSmagorinskyModel.so] Error 1
Do you know a work-around, so I can compile it as non-root?
Best regards,
Bernhard
BernhardGrieser is offline   Reply With Quote
Old   February 17, 2011, 09:37
  #27
Bernhard Grieser
ok, problem solved. One only has to change the content of ./Make/files:
I replaced FOAM_LIBBIN with FOAM_USER_LIBBIN
Old   February 17, 2011, 15:51
Alberto Passalacqua
Good the code is useful to someone :-)
Alberto Passalacqua
Old   April 1, 2011, 01:47
Default Thanks!
  #29
James Jewkes
JamesJCFD is on a distinguished road
Dear Alberto,
Many thanks for your contribution! This is just what I have been looking for...
kind regards,
James
JamesJCFD is offline   Reply With Quote
Old   April 1, 2011, 03:41
Alberto Passalacqua
Happy to share!
Alberto Passalacqua
Old   June 11, 2011, 23:06
Perry L. Johnson
PerryLJohnson is on a distinguished road
Alberto,
Just trying to understand your code (and OpenFOAM coding in general), not being picky.
If I have understood your code correctly, by changing the average(LLMM/MMMM) to fvc::average(LLMM/MMMM), you have averaged over the faces belonging to the cells, which are interpolated from their respective cells.
So essentially, you have applied the box filter (or simple filter as OpenFOAM calls it) and could accomplish the same thing using filter_(LLMM/MMMM) assuming the user chooses the simple filter. This would also allow use of the other filters to perform this averaging at the choice of the user. Please correct me if I have misunderstood anything.
FYI, the fluent manual states that it averages locally using the test filter, which appears to be what you have done as well (fluent also uses box filter).
Regards,
Perry
PerryLJohnson is offline   Reply With Quote
Old   June 11, 2011, 23:32
Alberto Passalacqua
Originally Posted by PerryLJohnson View Post
Alberto,
Yes, correct.
Yes. Notice however that FLUENT forces nu_sgs > 0, which is not the case, and I do not do.
Best,
Alberto Passalacqua
Old   June 11, 2011, 23:41
Perry L. Johnson
Yes, correct.
Best,
I did notice that. I know you want to allow for back-scattering, but is there a numerical danger in letting nuEff get *close* to zero? I guess not since the numerical diffusion would take over at this point (provided you were using a dissipative scheme). They also clip nuSgs at 0.23 which seems kinda arbitrary.
Perry
Old   June 12, 2011, 00:07
Alberto Passalacqua
Numerically I do not see any problem. It would just be like solving for an inviscid flow. Physically it could not be meaningful however.
Yes, I agree.
Best,
Alberto Passalacqua
Old   July 5, 2011, 10:57
Kris
kpsl is on a distinguished road
I am having some trouble compiling this on OpenFOAM 2.0.x.
I get the following error:
dynLocalAverageSmagorinsky.C:40:   instantiated from here
/home/kris/OpenFOAM/OpenFOAM-2.0.x/src/turbulenceModels/incompressible/LES/lnInclude/LESModel.H:115: error: no matching function for call to ‘Foam::incompressible::LESModels::dynLocalAverageSmagorinsky::dynLocalAverageSmagorinsky(const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::transportModel&, const Foam::word&)’
dynLocalAverageSmagorinsky.H:130: note: candidates are: Foam::incompressible::LESModels::dynLocalAverageSmagorinsky::dynLocalAverageSmagorinsky(const Foam::volVectorField&, const Foam::surfaceScalarField&, Foam::transportModel&)
dynLocalAverageSmagorinsky.H:118: note:                 Foam::incompressible::LESModels::dynLocalAverageSmagorinsky::dynLocalAverageSmagorinsky(const Foam::incompressible::LESModels::dynLocalAverageSmagorinsky&)
make: *** [Make/linux64GccDPOpt/dynLocalAverageSmagorinsky.o] Error 1
Is there an updated version for 2.0? Any help would be much appreciated
Kris
kpsl is offline   Reply With Quote
Old   July 5, 2011, 11:04
Bernhard
Bernhard is on a distinguished road
This was released by Alberto this morning:
https://github.com/AlbertoPa/dynamicSmagorinsky
shuige likes this.
Bernhard is offline   Reply With Quote
Old   July 5, 2011, 12:48
grandgo is on a distinguished road
hi alberto,
i'm using dynamicSmagorinsky for a LES in parallel processing.
i have this message. the calculation is running but i'm concerned because of this warning.
FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 78
    could not load /home/stss8/OpenFOAM/stss8-1.7.x/lib/linux64GccDPOpt/libdynamicSmagorinskyModel.so: undefined symbol: _ZNK4Foam14incompressible9LESModels11GenEddyVisc1BEv
do you know anything about this?
best regards
grandgo
grandgo is offline   Reply With Quote
Old   July 5, 2011, 13:04
Perry L. Johnson
grandgo,
I think your question is posed and answered in posts 21 and 22 respectively.
Perry
Old   July 5, 2011, 13:34
grandgo,
Perry
right. sorry.
(couldn't find the keywords via search function ...)
Old   July 5, 2011, 15:22
Alberto Passalacqua
I released it this morning. Note that the version for OpenFOAM 2.0.x *breaks* the compatibility with 1.7.x.
If you need both, take a look at the README. However I am not going to update the version for 1.7.x in case bugs are found.
P.S. Notice that OF 2.0.x comes with the dynLagrangian model, which uses Lagrangian averaging to find the dynamic coefficient. It is a more refined model than the traditional dynamic Smagorinsky, so it might be worth considering it too (the reference is in the header file).
Best,
Alberto Passalacqua
Smagorinsky Dynamic Cosant in UDF Paolo Lampitella FLUENT 1 June 17, 2009 04:40
Dynamic Smagorinsky LES Lourival FLUENT 0 April 14, 2006 14:48
Dynamic Smagorinsky Model Andrew Main CFD Forum 1 November 30, 2004 01:52
Reply to Tim Re Dynamic Smagorinsky model Ajay S. Parihar Main CFD Forum 9 June 2, 2002 17:24
Dynamic Smagorinsky model Tim Main CFD Forum 7 May 29, 2002 08:37
