porousSimpleFoam: oscillating velocity in the porous zone
Like Tree12Likes
Old   August 21, 2017, 04:06
Sebastian
sepp.zell is on a distinguished road
Originally Posted by krndv View Post
sorry , i am new to openfoam. Please tell me where to copy this (means which file and where in file)
thank you
Copy the source files of porousSimpleFoam to your case directory. The files can be found by using
cd $FOAM_SOLVERS/incompressible/simpleFoam
Copy the whole directory of porousSimpleFoam (as mentioned for icoFoam in the tutorial).
As mentioned in the bug-report you have to replace
U -= rUA*fvc::grad(p)
by
U = fvc::reconstruct(phi)
in the file pEqn.H. Also changes in
 .../Make/files
have to be done as mentioned in the icoFoam tutorial. Do not forget to give your solver a new name. Finally run
wmake
to compile the new solver.
sepp.zell is offline   Reply With Quote
Old   August 21, 2017, 06:49
karundev
krndv is on a distinguished road
by
 .../Make/files
wmake
Thanks for your Reply.
I am unable to find this equation , Can you please tell in which file it belongs to?
peq.h or ueq.h ?
krndv is offline   Reply With Quote
Old   August 22, 2017, 04:22
Sebastian
by
in the file pEqn.H.
As I wrote you have to look into the file pEqn.H.
Since I do not know, which version of openFoam you are using, I can not give you all the details. In the newest version it should correspond to
if (pressureImplicitPorosity)
    U = HbyA - (trTU()&fvc::grad(p));
else
    U = HbyA - (trAU()*fvc::grad(p));
I guess here you have to change the lines.
Oscillating velocity and porous zones alberto OpenFOAM Running, Solving & CFD 4 October 28, 2016 04:14
Heat source in porous zone anger OpenFOAM Running, Solving & CFD 11 December 16, 2013 10:49
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
Temperature drop after porous zone MN FLUENT 0 December 10, 2003 13:28
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
