April 12, 2016, 11:52 |
#21 |
Sami
Rep Power: 13 |
Hi Foamers,
Just an update, my simulations are still unstable when I use tetrahedral meshes. Using hex mesh seems to improve the stability but this kind of mesh is not easy to build when dealing with complex geometries. Do you have an idea how can I run stable simulations using tet meshes with multiphaseEulerFoam ? Thank you, Mhrz |
June 25, 2018, 10:00 |
#22 |
Noah Yao
Rep Power: 9 |
Hi Mhrz,
Did you manage to find a solution? I'm facing same problem with reactingTwoPhaseEulerFoam. The problem is gone when I use hex mesh, so I'm pretty confident that my IC and BC are correct. Thanks Noah |
June 25, 2018, 19:09 |
#23 |
Sami
Rep Power: 13 |
Just use hex meshes if possible. Otherwise, the problem is still there.
mhrz |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 03:54 |
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 10:47 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
convergence problem in comsol | anderson | COMSOL | 0 | February 24, 2008 16:54 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 05:24 |
