Error trying to run steady-state sonicFoam
Old   November 28, 2010, 13:30
Default Error trying to run steady-state sonicFoam
Daniel
dancfd is on a distinguished road
Hello all,
I receive a strange error when trying to run sonicFoam on my case. Eventually I want to run my case using sonicDyMFoam to have an oscillating airfoil. However, at this stage I only wish to test the simulation as a static, steady-state case. To do so, I ran moveDynamicMesh to get the airfoil angle where I wanted it, then copied the relevant /<time>/polyMesh/points file into the /constant/polyMesh directory, and edited the pointDisplacement file to prevent the mesh from moving further. However, when I try to run sonicFoam I get the following error:
Starting time loop
Time = 5e-08
Courant Number mean: 4.389700743e-05 max: 0.006296550206
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
--> FOAM FATAL ERROR:
mesh flux field does not exists, is the mesh actually moving?
    From function fvMesh::phi()
    in file fvMesh/fvMeshGeometry.C at line 392.
FOAM exiting
The simulation will run using sonicDyMFoam, though. Why is that? I do not want to solve the cellDisplacement equations if I do not need to, to speed up the simulation. sonicDyMFoam will not run with "steadyState" in the ddtSchemes subdict of system/fvSchemes, therefore I believe I need to use sonicFoam, but this error prohibits that!
Also, since this is a steady-state simulation, what is the best solver to use for compressible flow that will produce the same results as sonicDyMFoam for a steady case? As far as I can tell, sonicDyMFoam = sonicFoam + mesh motion, but which solver = sonicFoam but steady? I would guess rhoSimpleFoam. Note: these cases are all turbulent.
Thanks for the help,
Dan
dancfd is offline   Reply With Quote
Old   December 19, 2010, 12:45
Default Error Running rhoSimpleFoam
Daniel
Hello all,
I am struggling to run rhoSimpleFoam on a case where sonicDyMFoam runs, but produces poor results. I receive the following error when running rhoSimpleFoam:
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo<eConstThermo<perfectGas>>>>>
Not implemented
    From function basicThermo::h()
    in file basicThermo/basicThermo.C at line 259.
FOAM aborting
Can anyone suggest what the problem could be? Note that there are unfortunately no tutorials for this solver.
Thanks,
Dan
Old   February 12, 2013, 04:15
immortality's Avatar
Ehsan
immortality is on a distinguished road
change epsithermo to hpsithermo
immortality is offline   Reply With Quote
Steady State solver for High Mach No flows mecbe2002 OpenFOAM 10 July 6, 2021 04:56
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
SimpleFoam unable to reach steady state francois OpenFOAM Running, Solving & CFD 8 November 19, 2009 14:33
Monitor point values in a steady state simulation Kushagra CFX 2 July 13, 2008 21:03
steady state creeping flow dominik Main CFD Forum 4 March 29, 2004 10:29
