November 11, 2010, 04:53 |
Error using probes
Balkrishna Patankar
Rep Power: 17 |
My controlDict is as follows :
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application balBubbleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 50; deltaT 0.01; writeControl runTime; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; functions { probes { type probes; functionObjectLibs ("libsampling.so"); enabled true; outputControl timeStep; outputInterval 1; probeLocations ( (0.05 0.0 0.03) (0.25 0.0 0.09) (0.05 0.0 0.18) (0.25 0.0 0.36) (0.05 0.0 0.45) (0.25 0.0 0.60) (0.05 0.0 0.70) (0.25 0.0 0.80) (0.05 0.0 1.10) (0.25 0.0 1.20) ); fields ( alpha,Ua,Ub ); } fieldAverage1 { type fieldAverage; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; fields ( alpha { mean on; prime2Mean on; base time; } Ua { mean on; prime2Mean on; base time; } Ub { mean on; prime2Mean on; base time; } p { mean on; prime2Mean on; base time; } ); } } // ************************************************************************* // |
November 11, 2010, 10:42 |
Steven van Haren
Rep Power: 16 |
try probes1 as a name instead of probes, and remove keyword enabled.
I assume you get no warning at the start of the simulation that your probe locations are outside of the domain? |
November 12, 2010, 03:31 |
Balkrishna Patankar
Rep Power: 17 |
@steven i do not get any warning that the probe locations are outside of the domain
November 12, 2010, 03:55 |
Steven van Haren
Rep Power: 16 |
Did you try my other two suggestions?
Because that are the only two differences between your controlDict and mine. And mine works fine. |
November 12, 2010, 04:51 |
Balkrishna Patankar
Rep Power: 17 |
yes i tried them but still i get no folder
November 12, 2010, 04:55 |
Steven van Haren
Rep Power: 16 |
Mmmmm, strange.
If you send me the full case I can have a look here. You're using your own solver? |
openfoam, probe |
How do probes work? | steph79 | OpenFOAM | 1 | October 17, 2013 08:41 |
Resolving Velocity Magnitudes with Probes | steph79 | OpenFOAM | 2 | August 9, 2010 18:16 |
probes for a component of a volTensorField | titio | OpenFOAM Post-Processing | 0 | July 2, 2010 13:50 |
problems with probes() function in chtMultiRegionFoam | Victor | OpenFOAM | 0 | November 25, 2009 15:08 |
Probes and multiprocessor runs | grtabor | OpenFOAM Running, Solving & CFD | 1 | June 12, 2007 13:59 |
