The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver |
November 10, 2010, 01:47 |
任芸
Rep Power: 17 |
I am studying pressure correction equation in SIMPLE algorithm by OpenFOAM-1.5-dev, and now I encounter a tough problem. So, I need your help. The SIMPLE algorithm I studied is in the solver of MRFSimpleFoam and I want to add a new pressure prediction between the mass conserving pressure correction equation and the application of under-relaxation. Actually, the new pressure is the average pressure evaluated by multidimensional averaging. Thus ……………………………………………………………….….① Where, is a previous iteration of pressure field. is computed via pressure equation in SIMPLE of MRFSimpleFOAM. is evaluated by multidimensional averaging. is the distance between the owner point and neighbor cell centers. is the neighbor nodes Then, the new pressure field distribution () is used for correcting pressure and velocity by applying the under-relaxation, and this step is the same as it in SIMPLE . My problem is how to calculate and represents them in OpenFOAM codes. Thanks! |
SIMPLE pressure correction in compressible flows | Maarten de Jong | Main CFD Forum | 7 | April 30, 2012 02:23 |
Strcture of pressure correction equation in PISO stable over time ? | sebi | Main CFD Forum | 1 | October 26, 2010 22:19 |
Pressure correction equation,Ferziger and Peric | Hooman | Main CFD Forum | 1 | July 20, 2010 05:21 |
Pressure Correction Equation | Hooman | Main CFD Forum | 1 | June 22, 2010 11:54 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
