October 28, 2010, 12:46 |
rotatingWallVelocity
I am new to posting here, but I have been lurking for a bit. I am doing a project on swirling flow by rotating the bottom wall of a axial-semetric cylinder. I am using the rotatingWallVelocity BC for the bottom wall but I have a few questions. 1) I am using the icoFoam solver for the low Reynolds numbers but I am confused on how the dimensions are lining up. With rotatingWallVeloicty I define an "omega" for rotational velocity, so are the units icoFoam is using rad./s or a tangential velocity in m/s? 2) For the time step of the solver I must make sure the Co is below 1 for this solver. For the units to line up on Co the velocity must be in m/s but I am defining a rotational velocity, which do I use for Co? Thanks for any help you can provide, I will keep looking though my text books. |
October 28, 2010, 17:38 |
Masashi Ohbuchi
Rep Power: 17 |
1) If you use movingRatatingWallVelocity, dimension of omega is rpm (=min-1). 2) How about using adjustTimeStep option and setting maxCo in your controlDict. |
rotatingWallVelocity bc | Lodda | OpenFOAM | 8 | June 18, 2018 12:31 |
How to use rotatingWallVelocity boundary condition | terrybarnaby | OpenFOAM | 26 | February 7, 2018 19:53 |
timeVaryingUniformFixedValue | andrea.pasquali | OpenFOAM | 18 | October 22, 2012 08:30 |
rotatingWallVelocity BC | milleniumrider | OpenFOAM Running, Solving & CFD | 1 | September 16, 2010 12:00 |
Rotating cylinder | ole | OpenFOAM | 6 | February 10, 2010 05:45 |
