ControlDict: How to only get one time folder for the results? |
March 22, 2016, 07:40 |
#21 |
Rep Power: 14 |
Hey,
what kind of problem do you want to simulate? Can you maybe try to use the standard icoFoam solver and see if it lets you simulate passed the current time? |
March 22, 2016, 08:18 |
#22 |
Rep Power: 10 |
Well I tried using the icoFoam Solver...Still its increasing the time precision to 18..
--> FOAM Warning : From function Time:perator++() in file db/Time/Time.C at line 1055 Increased the timePrecision from 6 to 18 to distinguish between timeNames at time 12.1401 Time = 12.1401000000000003 Courant Number mean: 0.0076843727 max: 0.070992469 smoothSolver: Solving for Ux, Initial residual = 0.00017927652, Final residual = 9.515912e-009, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.00046194189, Final residual = 1.477745e-008, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.04602532, Final residual = 9.436656e-007, No Iterations 734 I wanted to solve the energy equation to calculate the Nusselt number. That is why I had to modify the icoFoam solver. Thanks!! |
March 22, 2016, 08:34 |
#23 |
Rep Power: 10 |
hey,
Here's one more problem that I've come across. This is completely unrelated to the previous problem about timePrecision. When I check the time steps that have been saved, the last time step is 3.35. The solver is currently at 7.1175 sec. Here's my controlDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application my_icoFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 40; deltaT 0.00025; writeControl adjustableRunTime; writeInterval 20; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; maxCo 0.6; adjustTimeStep yes; timePrecision 6; runTimeModifiable true; libs ( "libgroovyBC.so" "libgroovyStandardBCs.so" ); // ************************************************************************* // Last edited by wyldckat; March 26, 2016 at 05:49. Reason: Added [CODE][/CODE] markers |
March 22, 2016, 08:45 |
#24 |
Rep Power: 10 |
Okay I think I got my answer to the last question. I changed the writeControl ti timeStep and its saving data as expected.
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
