Cluster OpenFOAM [Solved]
Like Tree2Likes
Old   February 18, 2011, 14:02
falcao is on a distinguished road
May be this is your problem!
Usualy the Solver patch is /home/user/openfoam/user-1.7.0/applicatons/solvers/multiphase/bubblefoam
And tutorial patch is usualy
/home/user/openfoam/user-1.7.0/run/tutorials/multiphase/bubblefoam/case
It must be something like this in all machines of cluster.
falcao is offline   Reply With Quote
Old   February 18, 2011, 14:14
Try to install openfoam from ubuntu pack in all machines. I think it will work.
Old   November 7, 2011, 13:04
Default Will it work in 1.5-dev?
  #23
Robert
lordvon is on a distinguished road
Will this procedure work if substituting the name properly in OF1.5-dev?
I would try it myself, but I am waiting on my ethernet switch to come in. And I am looking for workarounds if there are issues.
lordvon is offline   Reply With Quote
Old   February 15, 2013, 09:26
Thiago Bassan Setala
tbsetala is on a distinguished road
You Sir saved my day!!!! Thank you very much!!!!!!!!
tbsetala is offline   Reply With Quote
Old   June 17, 2013, 21:57
Yahoo is on a distinguished road
Hi
I have been stuck on a problem related to simulation of a solidification problem on multiple processors. The problem is that at the pressure reference cell (pRefCell), I get a very weird behavior. Here is the liquid fraction contour when the simulation is performed on multiple processors.
Similar problem has been reported on:
(1) Poisson eq w setReference works serial diverges in parallel
http://www.cfd-online.com/Forums/ope...-parallel.html
(2) interfoam blows up on parallel run
http://www.cfd-online.com/Forums/ope...allel-run.html
(3) temperature anomaly at pressure reference cell
http://www.cfd-online.com/Forums/ope...ence-cell.html
What has been suggested in these posts is: (1) using GAMG solver instead of PCG as the pressure solver on parallel run, and (2) adjusting the fluxes after including the buoyancy term. I have applied both of the comments, although the second comment does not make a full sense for me, but still have the problem.
Please let me know if you have any comments.
Yahoo is offline   Reply With Quote
cluster, openfoam 1.7.1
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie OpenFOAM 10 April 19, 2021 19:06
Almost have my cluster running openfoam, but not quite... bjr OpenFOAM Running, Solving & CFD 17 March 6, 2020 10:52
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
How to install the OpenFoam in the cluster. Please help me! flying OpenFOAM Installation 6 November 27, 2009 04:00
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
