attachDetach: Not all zones and patches needed in the definition have been found. |
October 11, 2010, 07:13 |
#1 | ||
Patricia
Rep Power: 16 |
Dear all,
I have set up a small test case to understand how to use the attachDetach dynamic mesh modifier. It is a simple cavity, where I attempt to insert a horizontal barrier by replacing the corresponding faces with boundaries. The case, which I am trying to run with OF1.5-dev, is attached. The steps to run it are: Quote:
Please help me by running the attached case and suggesting where I have made a mistake. Thank you very much Patricia Last edited by schmittp54; October 20, 2010 at 09:55. |
October 12, 2010, 10:23 |
Yi Wang
Rep Power: 17 |
I didn't try your case. But my guess is you might need to do "setsToZones" to convert faceSet to faceZone.
Yi |
October 20, 2010, 10:26 |
Patricia
Rep Power: 16 |
Reposted as http://www.cfd-online.com/Forums/ope...achfvmesh.html because the initial error was solved, but other problems remain.
July 17, 2012, 09:40 |
Solution??
#4 | |
Hannes
Rep Power: 16 |
Cheers, Hannes. |
June 5, 2013, 17:31 |
Peng Zhong
Rep Power: 13 |
Could you please post your case files? Thanks.
