FV schemes
Old   September 27, 2010, 12:35
Default FV schemes
ala
Alicja M
ala is on a distinguished road
Hi all, I have a question. Can i deal in open foam with dual meshes?
I mean, can i also do finite volume discretisation as node (vertex) centered fv scheme? Thanks in advance! Best regards, Alicja
ala is offline   Reply With Quote
Old   October 14, 2010, 15:14
ala
Alicja M
I know that OpenFoam use collocated grids. But i'm not sure about the FV schemes. Do the finite volume cells agree with mesh cells? Can i also define a finite volume around a vertex (vertex centered) and not around a cell center (cell-centered)? I already looked at the fvMatrix class, and i'm thinking that this is impossible (or hard to do).
thanks!
ala
Old   October 14, 2010, 15:32
ala
Alicja M
I modified a little bit the laplacianFoam in the following way:
- first I read a volScalarField f=1 (right hand side)
- next I modify this volScalarField f within the solver to f=sin( pi x )sin( pi y )
- and last i solve -\Delta \phi = f with constant (equal to 0) Dirichlet BC, with \phi : \mathbb{R}^n \rightarrow \mathbb{R}
Is it OK like i did it?
I 've attached the modified solver and the case.
Comments and hints are appreciated!
Greetings,
Ala
Old   October 19, 2010, 17:25
Default Please any help is still appreciated!
ala
Alicja M
Has nobody a hint or an idea?
Thanks in advance,
Alicja
time stepping schemes for compressible DNS/LES shyamdsundar Main CFD Forum 0 January 15, 2010 00:15
ENERGY CONSERVATION SCHEMES! Science Seeker Main CFD Forum 1 May 24, 2001 13:13
Energy Conservation Schemes! Science Seeker Main CFD Forum 0 May 21, 2001 04:31
Advection schemes for LES kalyan Main CFD Forum 2 May 17, 2001 14:43
Higher-order bounded convection schemes for pure advection with discontinuity Anthony Main CFD Forum 3 June 13, 1999 03:36
