Dimensions !
Old   September 23, 2010, 07:45
Post Dimensions !
T.D. is on a distinguished road
Hi everybody,
Please Please, i need to stop all these "dimensions stuff", they are turning me crazy!!!
because my equation is so complicated, and i need to solve it without any dimensions even for the Ueqn and P and correction i mean for all
I mean even for icoFoam forexample, so How to switch OFF all dimensions
in my application solver, and not in the all root openfoam directories.
Thanks a lot
T.D.
T.D. is offline   Reply With Quote
Old   September 23, 2010, 17:10
David Gaden
marupio is on a distinguished road
Do you have access to OpenFOAM-1.x.x/etc/controlDict? If so, find the dimensionSet entry in DebugSwitches and set it to 0.
Better yet, are you writing your own solver? If so, start with:
dimensionSet::debug = 0;
Hopefully that works.
marupio is offline   Reply With Quote
Old   September 24, 2010, 03:18
Alberto Passalacqua
In my experience, turning off the dimensional check is not smart. It often saves you from making obvious mistakes and finds almost all typos in complicated equations.
You are coding something complex: it is exactly when you need automatic checks like these :-)
Of course, just my two cents ;-)
Alberto Passalacqua
Old   September 24, 2010, 04:11
Post Thanks
Hi alberto,
finally i let it on, and you are right i descovered many mistakes and solved them, thanks,
i have a question for you please
In the Ico Foam solver, how can i change "nu" to be a function of a scalarField knowing that nu is a dimensioned scalar for example
if i need to solve
fvm::ddt(c)+fvc::div(phi,c) == etc.... (c is a volScalarField defined without any dimension)
but before it i have in the UEqn in IcoFoam "nu" and i need that my nu=(1-c/0.68)
help please
thanks
Old   September 24, 2010, 15:26
Alberto Passalacqua
Define a volScalarField called nuEff after reading nu from transportProperties
volScalarField nuEff
        IOobject
            "nuEff",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
        nu
Then use this field instead of nu in the UEqn, and update nuEff according to your law.
Alberto Passalacqua
[snappyHexMesh] stl and snappyHexMesh dimensions mismatch romant OpenFOAM Meshing & Mesh Conversion 11 May 4, 2015 10:44
Incompatible dimensions.... Amiga500 OpenFOAM Running, Solving & CFD 13 June 1, 2012 08:20
Different dimensions for FATAL ERROR retech OpenFOAM Running, Solving & CFD 2 August 14, 2007 11:17
Dimensions of laplacian in PISO loop kumar2 OpenFOAM Running, Solving & CFD 2 July 3, 2006 15:34
Fluent: changing dimensions of a geometry genetaed Madhukar Rapaka FLUENT 3 October 12, 2005 12:40
