Pressure in rhoSimpleFoam
Old   September 16, 2010, 10:34
Default Pressure in rhoSimpleFoam
Vitor Braga
vitor is on a distinguished road
I'm running a simple simulation, an axial air flow through a pipe. It's compressible, with a Mach = 0,5 . I'm still setting the BC's, the problem is: which pressure I should set in the 0/p file? Is it the relative or absolute pressure?
I know that using fixedValue means that I'm setting static pressure, and totalPressure sets static+dynamic. But do I need to add the atmosferic pressure?
Let's say, if my atm pressure is 101 kPa and I want relative totalPressure @ inlet equal to 18 kPa. Then I should use 18 or 119 kPa in the 0/p file?
Thanks a lot.
Vitor
vitor is offline   Reply With Quote
Old   September 16, 2010, 11:03
Stefan Herbert
herbert is on a distinguished road
Hi Vitor,
of course you have to define 119 kPa in your example. Atmospheric pressure is not defined elsewhere. Therfore the absolute pressure is needed to make sure that the density is calculated correctly.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   September 16, 2010, 12:49
Vitor Braga
Indeed. I thought maybe the atmosferic pressure would be set in other file.
Thank you for your reply.
And sorry for the fundamental question...
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 12:49
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 14:23
Pressure Boundary Problems Chris Siemens 2 June 21, 2005 09:20
