two mixing compresible fluids solver
Like Tree2Likes
Old   April 23, 2015, 07:11
Jignesh Chokshi
Jimmy Chokshi is on a distinguished road
Originally Posted by ziemowitzima View Post
Give me your email, I will send you the working case with few words of explanations.
I would attached it here, but size of the file seems to be too large (1.4MB), and I could not attached it to my reply.
best
Can you please send this working case to chokshirl@gmail.com ?
Many thanks !!
Jimmy Chokshi is offline   Reply With Quote
Old   April 23, 2015, 07:14
Jignesh Chokshi
Many thanks !!
Old   May 20, 2020, 07:14
Hendrik von Schöning
HVonSch is on a distinguished road
Hello everyone,
I had the same problem (multi-fluid-mixing flow, single phase, compressible, stationary).
I combined rhoSimpleFoam and reactingFoam to a new solver, which integrates in rhoSimpleFoam.
I called it rhoMixingSimpleFoam. It is attached to this post.
EDIT: Please keep in mind, that this solver is not well tested or validated in any way!
Also: In this solver the turbulent species transport is modelled via alphat and is thus equal to the turbulent heat fluxes. This is not always the case!
Installation:
Just copy the dir "rhoMixingSimpleFoam" to the rhoSimpleFoam-directory (/path_to_Openfoam/applications/solvers/compressible/rhoSimpleFoam/), enter it and run wmake.
Also attached is the following thermophysicalProperties which is used by this solver:
thermoType
    type            heRhoThermo;
    mixture         multiComponentMixture;
    transport       sutherland;
    thermo          janaf;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
inertSpecie air;
species (air CO2);
air
    specie
        nMoles          1;
        molWeight       28.965; // (refprop)
    equationOfState
        pRef            1e6;
    thermodynamics
        Tlow            200;
        Thigh           6000;
        Tcommon         1000;
        highCpCoeffs    ( 3.08792717E+00 1.24597184E-03 -4.23718945E-07 6.74774789E-11 -3.97076972E-15 -9.95262755E+02 5.95960930E+00 );
        lowCpCoeffs     ( 3.56839620E+00 -6.78729429E-04 1.55371476E-06 -3.29937060E-12 -4.66395387E-13 -1.06234659E+03 3.71582965E+00 );
        // no source, sorry
    transport
        As          1.460846342e-06; // (White - Viscous Fluid Flow)
        Ts          111;
CO2
    specie
        nMoles          1;
        molWeight       44.01; // (refprop)
    equationOfState
        pRef            1e6;
    thermodynamics
        Tlow            200;
        Thigh           3500;
        Tcommon         1000;
        highCpCoeffs    ( 3.85746029E+00 4.41437026E-03 -2.21481404E-06 5.23490188E-10 -4.72084164E-14 -4.87591660E+04 2.27163806E+00 );
        lowCpCoeffs     ( 2.35677352E+00 8.98459677E-03 -7.12356269E-06 2.45919022E-09 -1.43699548E-13 -4.83719697E+04 9.90105222E+00 );
         //http://combustion.berkeley.edu/gri-mech/data/nasa_plnm.html
    transport
        As              1.503425096e-06; // (White - Viscous Fluid Flow)
        Ts              222;
petr.f. likes this.
Last edited by HVonSch; June 2, 2020 at 08:30. Reason: Added information about validity and assumptions
HVonSch is offline   Reply With Quote
Old   May 31, 2020, 16:15
Kamal Khemani
KAMAL KHEMANI is on a distinguished road
Originally Posted by HVonSch View Post
Hello everyone,
thermoType
    type            heRhoThermo;
    thermo          janaf;
    specie          specie;
inertSpecie air;
species (air CO2);
air
    specie
        nMoles          1;
    equationOfState
        pRef            1e6;
    thermodynamics
        Tlow            200;
        Thigh           6000;
        Tcommon         1000;
        // no source, sorry
    transport
        Ts          111;
CO2
    specie
        nMoles          1;
    equationOfState
        pRef            1e6;
    thermodynamics
        Tlow            200;
        Thigh           3500;
        Tcommon         1000;
    transport
        Ts              222;
Hi HVonSch, with laminar conditions the temperature shoots up at very high value any reason for that ?
KAMAL KHEMANI is offline   Reply With Quote
Old   June 2, 2020, 08:33
Hello Kamal,
Is the simulation fully converged?
Please provide more information about your case and the way you are using the species mixing (species, phases) to track down if the error is caused by the solver modification.
Best regards,
Hendrik
Old   June 15, 2020, 16:59
Petr Furmanek
petr.f. is on a distinguished road
Hi Hendrik, I'm checking out your solver (nice work btw.). How do you prescribe boundary conditions for the individual species? Is it in the same way as in case of reactingFoam i.e. by individual files in constant/ dir as e.g. "air" and "CO2"?
petr.f. is offline   Reply With Quote
Old   June 16, 2020, 03:04
Hello Petr,
thank you!
Yes, BCs are prescribed as in reactingFoam.
For example for CO2:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      CO2;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    INLET
        type            fixedValue;
        value           uniform 0;
    OUTLET
        type            inletOutlet;
        value           uniform 0;
        inletValue      uniform 0;
    PLENUM_INLET
        type            fixedValue;
        value           uniform 1;
    PLENUM_OUTLET
        type            inletOutlet;
        value           uniform 1;
        inletValue      uniform 1;
    WALL
        type            zeroGradient;
You don't need a BC-file for the "inert species" as its fraction is just 1-sum(other species fractions).
Best,
Hendrik
Old   August 13, 2020, 13:40
nikhil108's Avatar
Nikhil
nikhil108 is on a distinguished road
Hallo Foamers,
can you suggest me a solver for, propane jet leak in to air. Right now, i am using reactingbuoyantfoam, but i want to add dynamic mesh, which is not supported by reactingFoam. any suggestions?.
cheers,
nm.
nikhil108 is offline   Reply With Quote
compressible flow, mixing gases
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 13:44
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 08:45
mixing 4 kind of fluids ranap CFX 2 September 19, 2008 12:55
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
Error during Solver cfd guy CFX 4 May 8, 2001 07:04
