Negative Total Pressure in cavitatingFoam RAS/Throttle Case in OF 1.6
Old   August 30, 2010, 16:59
Default Negative Total Pressure in cavitatingFoam RAS/Throttle Case in OF 1.6
Michael Ahlmann
danishdude is on a distinguished road
I'm working on modelling cavitating flow in a series of control valves, and my plan was to use cavitatingFoam to do so. However, when running the "Throttle" tutorial case in the "RAS" subfolder, I noticed that the total pressures (calculated using ptot utility) go negative which seems unphysical. I know that in some other CFD solvers there is a reference pressure somewhere, does OpenFOAM use anything similar? If not, can somebody explain why the negative pressure shows up?
danishdude is offline   Reply With Quote
Old   September 6, 2010, 06:36
Default same problem...
nico9238 is on a distinguished road
I need to simulate the cavitation in an injector. To get more familiar with the code dedicated to the cavitation in openFoam, I try to run the throttle tutorials case.
I also got some negative value for the pressure. Moreover I can observe some backflow from the outlet and a kind of pressure wave... I donīt know how to solve the problem. If you have any idea, would be great!
thx
nico9238 is offline   Reply With Quote
cavitatingfoam, multiphase, negative pressure, negative total pressure
total pressure change in a pipe flow Im FLUENT 5 February 23, 2017 09:55
negative static pressure Selo melo FLUENT 5 December 18, 2006 10:30
negative pressure mAx FLUENT 0 January 25, 2006 15:31
Total pressure to static pressure ratio roadracer Siemens 1 April 17, 2003 06:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
