Mehdi
Rep Power: 16 ![]() |
Hello everyone ,
i did a few changes in the solver mdfoam.c and when i try to recompile it i encounter this error which i dont know what it is HTML Code:
mehdi@mehdi-laptop:~/OpenFOAM/OpenFOAM-1.6/applications/solvers/discreteMethods/molecularDynamics/mdFoam$ wclean libso wclean ./ mehdi@mehdi-laptop:~/OpenFOAM/OpenFOAM-1.6/applications/solvers/discreteMethods/molecularDynamics/mdFoam$ wmake Making dependency list for source file mdFoam.C SOURCE=mdFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/potential/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecularMeasurements/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/mdFoam.o In file included from mdFoam.C:50: /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H: In function ‘int main(int, char**)’: /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:5: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:11: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:17: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:23: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:37: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:43: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:52: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:92: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:98: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:107: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:147: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:153: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:162: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:221: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:227: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:236: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:277: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:283: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:292: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ In file included from mdFoam.C:67: /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/calculateMDFields.H:13: error: ‘class Foam::molecule’ has no member named ‘U’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/calculateMDFields.H:17: error: ‘class Foam::molecule’ has no member named ‘mass’ In file included from mdFoam.C:69: /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:5: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:11: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:17: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ /home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:23: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’ make: *** [Make/linuxGccDPOpt/mdFoam.o] Error 1 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Getting too many iterations by velocity solving (aborting). Changing U - Solver? | suitup | OpenFOAM Running, Solving & CFD | 0 | January 20, 2010 07:45 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
