Reference frame solver with GGI
Old   August 26, 2010, 00:34
Default Reference frame solver with GGI
Pavan
rieuk is on a distinguished road
Hey guys, I'm simulating 2D flapping wing flow and I've so far got rotation to work using GGI -I'm trying to incorporate translation now which should be a straightforward application of a non-inertial reference frame but I'm wondering if there's any solver already designed to do this.
rieuk is offline   Reply With Quote
Old   August 26, 2010, 11:03
Pavan
Now that I think about it, it seems like it might be a little more complicated that I first thought with respect to the boundary conditions. At the moment I have flow over a rotating wing section. But now I'd like to translate it up and down as well. What's the simplest way to do this in OpenFOAM?
Old   August 27, 2010, 05:01
Pavan
Any ideas? ...If it's just a matter of adding a time dependent acceleration term into the momentum equation then it's simple but do I need to derive the pressure boundary condition at the wing wall or can I leave it as zero-gradient (which is non-physical)?
Old   August 30, 2010, 06:08
Pavan
What's the syntax to add a sinusoidally varying acceleration term to my momentum equation? Do I create a volScalarField and multiply with mesh().C()? And how do I reference the current time? Using time().value() ??
Old   September 5, 2010, 05:55
Pavan
Anyway the solution was the following:
scalar Pi = mathematicalConstant::pi;
dimensionedScalar accCt("accCt",dimensionSet(0,1,-2,0,0,0,0),10000*Foam::cos(2*Pi*runTime.value()/0.5));
 dimensionedVector acc("acc",dimensionSet(0,1,-2,0,0,0,0), vector::zero);
 acc.component(vector::X) = 0.5 * accCt;
acc.component(vector::Y) = 0.5 * Foam::sqrt(3.0) * accCt;
        fvVectorMatrix UEqn
             fvm::ddt(U)
          + fvm::div(phi, U)
            - fvm::laplacian(nu, U)
          acc
        solve(UEqn == -fvc::grad(p));
Now I need to take care of the BCs using sinusoidally varying velocity conditions. What BC can do this? groovyBC?
how to treat the rotating zone in multiple reference frame (MRF) Jiuan FLUENT 4 May 24, 2010 22:58
Building OF 1.6 - CentOS 4.x Pytthon OpenFOAM 1 February 2, 2010 12:05
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
Gravity in single rotating reference frame QinxueTan FLUENT 0 May 7, 2008 07:59
Multiple reference frame Lim FLUENT 1 April 19, 2008 11:46
