Error while running rhoPisoFoam..
Old   August 23, 2010, 09:32
Default Error while running rhoPisoFoam..
Nilesh Rane
nileshjrane is on a distinguished road
I am trying to solve a case using rhoPisoFoam. I have set up the case. I am using the mesh from "engrid".
When i run rhoPisoFoam command i get following error. I am quite new to OF and have no aptitude to analyze the error. Please help someone.
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::hPsiThermo(Foam::fvMesh const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
in "/opt/openfoam170/applications/bin/linux64GccDPOpt/rhoPisoFoam"
#8 __libc_start_main in "/lib/libc.so.6"
Floating point exception
Thanks in advance.
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
Old   August 25, 2010, 03:50
Christian Lucas
Chris Lucas is on a distinguished road
we need more information about the case to help you (0 + system folder)
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   August 25, 2010, 07:19
Nilesh Rane
PFA the files...
I cant give the mesh file..
Thank you
Old   August 25, 2010, 08:33
Christian Lucas
at your inlets, you have both a fixed pressure and a fixed velocity. This will result into bad results, either give a pressure or a velocity or the totalpressure.
Secondly, you start your simualition with 0 temperature and 0 pressure (internal grid). This results into the crash above
Regards,
Christian
Old   August 25, 2010, 08:40
Christian Lucas
I totally forgot to ask, could you tell me a bit more about your simulation? What are you simulating?
If your get a converged solution (have a look at the outflow BC) would you share the case files with me?
I also saw that you used engrid. So you don't use an structured grid. In this case, I would increase the nNonOrthogonalCorrectors
Regards,
Christian
Old   August 25, 2010, 13:46
Default Thanks for the help
Nilesh Rane
Hello Chris,
Thank you very much for the help. I will try these suggestions.
I am trying to simulate the flow in a secondary combustor of a ducted rocket. I am a newbie. This is my 1st OpenFoam Simulation so i am learning right now. I will eventually be doing a "reatingFoam" simulation but this is just a start up thing to get an idea about mesh requirements and computational time and rough outline of the flow in the combustion chamber.
I would be happy to share the results with you, may not be exact things, but certainly enough so that it will be useful for you.
And yes i am using engrid mesh for this, but i am planning to switch to blockMesh, which is bit tough. But any way what is this nNonOrthogonalCorrectors parameter??? I certainly observed that checkMesh marked some cells for nonorthogonality.
Old   August 26, 2010, 11:32
Nilesh Rane
Hey chris, i followed your suggestions and it worked. But Now i am getting this error..
Create time
Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model RNGkEpsilon
RNGkEpsilonCoeffs
Cmu 0.0845;
C1 1.42;
C2 1.68;
C3 -0.33;
sigmak 0.71942;
sigmaEps 0.71942;
Prt 1;
eta0 4.38;
beta 0.012;
Creating field DpDt
Courant Number mean: 1.22796e-09 max: 8.95587
Starting time loop
Time = 0.001
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.62694e-09, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 3.70722e-08, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 2.81053e-08, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 7.52452e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 9.58054e-07, No Iterations 22
DICPCG: Solving for p, Initial residual = 0.058323, Final residual = 6.70937e-07, No Iterations 15
time step continuity errors : sum local = 1.30722e-08, global = -2.03457e-09, cumulative = -2.03457e-09
DILUPBiCG: Solving for h, Initial residual = 0.341511, Final residual = 9.5375e-06, No Iterations 72
DICPCG: Solving for p, Initial residual = 0.0347524, Final residual = 9.78405e-07, No Iterations 17
DICPCG: Solving for p, Initial residual = 0.00946983, Final residual = 7.95556e-07, No Iterations 12
time step continuity errors : sum local = 1.85103e-08, global = -2.54992e-09, cumulative = -4.58449e-09
DILUPBiCG: Solving for epsilon, Initial residual = 0.237027, Final residual = 3.64654e-06, No Iterations 5
bounding epsilon, min: -96049.6 max: 190800 average: 6173.85
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 6.25202e-06, No Iterations 11
bounding k, min: -73.4857 max: 208.056 average: 54.9564
ExecutionTime = 23.37 s ClockTime = 24 s
Courant Number mean: 0.00165936 max: 7.69453
Time = 0.002
DILUPBiCG: Solving for Ux, Initial residual = 0.922667, Final residual = 2.17974e+07, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.955363, Final residual = 151476, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = 0.846495, Final residual = 413.085, No Iterations 1001
DILUPBiCG: Solving for h, Initial residual = 0.388612, Final residual = 2.77765e-12, No Iterations 2
DICPCG: Solving for p, Initial residual = 1, Final residual = 7.64242e-07, No Iterations 33
DICPCG: Solving for p, Initial residual = 0.410692, Final residual = 7.64002e-07, No Iterations 35
time step continuity errors : sum local = -0.000115618, global = 1.56698e-05, cumulative = 1.56652e-05
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 3.41158e+15, No Iterations 1001
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#6 __libc_start_main in "/lib/libc.so.6"
Old   August 26, 2010, 11:49
Thumbs up
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
hi nilesh and chris
what chris suggested is correct. but the above error getting with the time step decrease your time step and give the run.
kiran is offline   Reply With Quote
Old   August 26, 2010, 13:50
Nilesh Rane
Thanx Kiran for your reply.
I reduced the time step by 10 times and this what i got. It looks like the trouble is in the thermophysical model. I am not sure.
Starting time loop
Courant Number mean: 1.22796e-10 max: 0.895587
Time = 0.0001
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.87779e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 7.41559e-07, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 6.19441e-07, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 2.09039e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 4.11979e-07, No Iterations 5
DICPCG: Solving for p, Initial residual = 0.00232814, Final residual = 2.76483e-07, No Iterations 3
time step continuity errors : sum local = 3.30784e-10, global = 1.38835e-11, cumulative = 1.38835e-11
DILUPBiCG: Solving for h, Initial residual = 0.134979, Final residual = 9.74829e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0227705, Final residual = 7.47325e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.000463772, Final residual = 3.39987e-07, No Iterations 2
time step continuity errors : sum local = 5.34991e-10, global = -3.69048e-11, cumulative = -2.30213e-11
DILUPBiCG: Solving for epsilon, Initial residual = 0.0343935, Final residual = 1.10077e-06, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 2.12824e-09, No Iterations 2
ExecutionTime = 10.9 s ClockTime = 11 s
Courant Number mean: 1.20987e-05 max: 0.797478
Time = 0.0002
DILUPBiCG: Solving for Ux, Initial residual = 0.205542, Final residual = 9.03849e-06, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.289117, Final residual = 2.23436e-08, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.307097, Final residual = 1.79424e-08, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.085322, Final residual = 8.0458e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0880967, Final residual = 2.97441e-07, No Iterations 4
DICPCG: Solving for p, Initial residual = 0.000952785, Final residual = 6.41826e-07, No Iterations 2
time step continuity errors : sum local = 2.21269e-09, global = -2.32879e-10, cumulative = -2.559e-10
DILUPBiCG: Solving for h, Initial residual = 0.0118797, Final residual = 8.1934e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00496357, Final residual = 1.7529e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 9.23467e-05, Final residual = 8.80519e-08, No Iterations 2
time step continuity errors : sum local = 3.22126e-10, global = 1.15796e-11, cumulative = -2.44321e-10
DILUPBiCG: Solving for epsilon, Initial residual = 0.0350901, Final residual = 1.05707e-06, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.920835, Final residual = 8.11466e-06, No Iterations 1
ExecutionTime = 17.77 s ClockTime = 18 s
Courant Number mean: 3.41131e-05 max: 0.897386
Time = 0.0003
DILUPBiCG: Solving for Ux, Initial residual = 0.151932, Final residual = 8.49855e-08, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.21195, Final residual = 2.06176e-07, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.223712, Final residual = 1.66182e-07, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.049634, Final residual = 4.58421e-08, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0482174, Final residual = 1.28071e-07, No Iterations 4
DICPCG: Solving for p, Initial residual = 0.000541171, Final residual = 2.76306e-07, No Iterations 2
time step continuity errors : sum local = 1.61954e-09, global = -2.34582e-10, cumulative = -4.78903e-10
DILUPBiCG: Solving for h, Initial residual = 0.00724666, Final residual = 8.76892e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00257986, Final residual = 8.07522e-08, No Iterations 3
DICPCG: Solving for p, Initial residual = 5.6645e-05, Final residual = 7.99804e-07, No Iterations 1
time step continuity errors : sum local = 4.80107e-09, global = -3.77017e-11, cumulative = -5.16605e-10
DILUPBiCG: Solving for epsilon, Initial residual = 0.0361042, Final residual = 7.68723e-07, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.844035, Final residual = 8.16512e-08, No Iterations 2
ExecutionTime = 25.8 s ClockTime = 26 s
Courant Number mean: 5.66831e-05 max: 0.933628
Time = 0.0004
DILUPBiCG: Solving for Ux, Initial residual = 0.132155, Final residual = 2.49781e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.165191, Final residual = 4.44447e-07, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.171887, Final residual = 3.12837e-07, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0357992, Final residual = 1.22762e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0333674, Final residual = 7.34194e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.000368354, Final residual = 1.84803e-07, No Iterations 2
time step continuity errors : sum local = 1.5441e-09, global = -1.1163e-10, cumulative = -6.28235e-10
DILUPBiCG: Solving for h, Initial residual = 0.00515052, Final residual = 6.56499e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00197868, Final residual = 9.11631e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 4.5262e-05, Final residual = 5.74115e-07, No Iterations 1
time step continuity errors : sum local = 4.84736e-09, global = 1.43854e-10, cumulative = -4.84381e-10
DILUPBiCG: Solving for epsilon, Initial residual = 0.0370731, Final residual = 1.62294e-06, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.778115, Final residual = 5.94707e-08, No Iterations 2
ExecutionTime = 33.37 s ClockTime = 33 s
Courant Number mean: 8.05815e-05 max: 0.915753
Time = 0.0005
DILUPBiCG: Solving for Ux, Initial residual = 0.119022, Final residual = 4.19624e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.133851, Final residual = 3.96336e-07, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.13697, Final residual = 2.76525e-07, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0282239, Final residual = 1.98228e-06, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0255723, Final residual = 5.3407e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.00027617, Final residual = 1.5248e-07, No Iterations 2
time step continuity errors : sum local = 1.65153e-09, global = -2.42189e-11, cumulative = -5.08599e-10
DILUPBiCG: Solving for h, Initial residual = 0.00386754, Final residual = 4.24874e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00166888, Final residual = 6.17623e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 3.4249e-05, Final residual = 3.91094e-07, No Iterations 1
time step continuity errors : sum local = 4.25402e-09, global = 5.92587e-11, cumulative = -4.49341e-10
DILUPBiCG: Solving for epsilon, Initial residual = 0.0380748, Final residual = 1.67708e-06, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.720784, Final residual = 9.89163e-07, No Iterations 2
ExecutionTime = 40.78 s ClockTime = 41 s
Courant Number mean: 0.000104574 max: 0.903535
Time = 0.0006
DILUPBiCG: Solving for Ux, Initial residual = 0.0892196, Final residual = 4.98543e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.112749, Final residual = 1.45864e-08, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.113052, Final residual = 3.14392e-07, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0233424, Final residual = 7.72495e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0207514, Final residual = 3.9847e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.000216915, Final residual = 1.1116e-07, No Iterations 2
time step continuity errors : sum local = 1.46998e-09, global = -2.13446e-11, cumulative = -4.70685e-10
DILUPBiCG: Solving for h, Initial residual = 0.00299696, Final residual = 3.01225e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00138315, Final residual = 4.32967e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 2.57837e-05, Final residual = 2.65555e-07, No Iterations 1
time step continuity errors : sum local = 3.51588e-09, global = 7.22215e-12, cumulative = -4.63463e-10
DILUPBiCG: Solving for epsilon, Initial residual = 0.0391174, Final residual = 6.05495e-06, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.670561, Final residual = 1.17086e-06, No Iterations 2
ExecutionTime = 48.8 s ClockTime = 49 s
Courant Number mean: 0.000127933 max: 0.89512
Time = 0.0007
DILUPBiCG: Solving for Ux, Initial residual = 0.0711607, Final residual = 3.87349e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.0995307, Final residual = 2.63544e-06, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.0967057, Final residual = 2.82658e-06, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0199164, Final residual = 1.25373e-06, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0174957, Final residual = 2.88932e-07, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.00017554, Final residual = 7.89031e-08, No Iterations 2
time step continuity errors : sum local = 1.22307e-09, global = -3.75482e-11, cumulative = -5.01012e-10
DILUPBiCG: Solving for h, Initial residual = 0.0025312, Final residual = 2.31581e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00118355, Final residual = 3.23954e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 2.01077e-05, Final residual = 1.85316e-07, No Iterations 1
time step continuity errors : sum local = 2.87206e-09, global = -4.68029e-12, cumulative = -5.05692e-10
DILUPBiCG: Solving for epsilon, Initial residual = 0.0401262, Final residual = 1.16225e-06, No Iterations 2
bounding epsilon, min: -507.023 max: 102191 average: 5784.06
DILUPBiCG: Solving for k, Initial residual = 0.626073, Final residual = 2.18301e-06, No Iterations 2
ExecutionTime = 56.85 s ClockTime = 57 s
Courant Number mean: 0.000150306 max: 0.892816
Time = 0.0008
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.59089e-06, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 8.59089e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.59089e-06, No Iterations 3
DILUPBiCG: Solving for h, Initial residual = 0.017391, Final residual = 1.0488e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 1, Final residual = 7.85576e-08, No Iterations 6
DICPCG: Solving for p, Initial residual = 0.0266224, Final residual = 4.79873e-07, No Iterations 4
time step continuity errors : sum local = 1.98554e-05, global = 2.57265e-06, cumulative = 2.57215e-06
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 5.85321e-06, No Iterations 167
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/opencfd/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
FOAM aborting
#1 Foam::error::abort() in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/opt/openfoam170/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#5 __libc_start_main in "/lib/libc.so.6"
Aborted
What do you CFD guys do during a long simulation running? bearcat Main CFD Forum 5 July 23, 2009 09:08
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Tutorial is not running on star-CD version 3.2 Arnab Siemens 0 August 30, 2004 16:43
star is not running the simulation in windows Arnab Siemens 1 August 2, 2004 03:40
