Using interFoam, phase piles up at pipe outlet
Old   August 22, 2010, 16:34
Default Using interFoam, phase piles up at pipe outlet
kjetil is on a distinguished road
Dear foamers,
I have put up a relatively simple case using interFoam, based on the approach in damBreak and 2D nozzle tutorials. I use setFields to "place" a load of water inside a pipe, which then is supposed to flush through the S-shaped geometry, and out. However, the water does not seem to exit the pipe at all. I have the following BCs (using OF 1.7.x):
alpha0:
inlet
type inletOutlet;
inletValue uniform 0;
value uniform 0;
outlet
type inletOutlet;
value uniform 0;
U:
inlet
type zeroGradient;
outlet {
type zeroGradient;
p_rgh:
inlet
type fixedValue;
value uniform 0;
outlet
type fixedValue;
value uniform -200;
kjetil is offline   Reply With Quote
Old   August 23, 2010, 04:44
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
You force alpha0 to be zero all the time at the inlet an outlet.
I think a zeroGradient would be more appropriate - at least for the outlet.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   August 23, 2010, 07:35
Are you sure about this? My perception of the inletOutlet "value", is that this is the initial value, and changes as the simulation proceeds. Though if this was a fixedValue type, I would agree...
Old   August 23, 2010, 09:39
sega's Avatar
Sebastian Gatzka
The inletOutlet
switches and between fixedValue and zeroGradient depending on direction of
(http://www.openfoam.com/docs/user/bo...hp#x24-1390293)
The value-entry will then correspond to the case of fixedValue.
But I'm not sure how this "switch" will work.
But there is some fixedValue involved in this may be the problem.
I think inletOutlet is better for velocity or pressure, not for alpha0.
Old   August 24, 2010, 04:18
I do see your point. The tutorials for interFoam, however, all use inletOutlet for alpha0.
interfoam, outlet, pipe
Finding Volume fraction at outlet when it changes its phase. praveen.jpk Main CFD Forum 1 August 18, 2014 08:18
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 07:52
Reverse Flow at Rotating Pipe Outlet vismech STAR-CCM+ 1 August 11, 2009 11:38
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
