Solving problem in "cavity with pisoFoam LES" |
August 10, 2010, 15:40 |
Hi FOAMers;
i want solve lid driven cavity with LES. i used files in tutorial file pisoFoam/LES/. After creating cavity mesh and adjusting boundary conditions in 0 and polymesh folders and typing pisoFoam leads to: HTML Code:
Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi --> FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply either pRefCell or pRefPoint file: /home/maysam/OpenFOAM/maysam-1.7.0/cavityRatio/10000LES/system/fvSolution::PISO from line 71 to line 72. From function void Foam::setRefCell ( const volScalarField&, const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 115. FOAM exiting Best, Maysam |
September 30, 2010, 00:37 |
#2 | |
Rep Power: 17 |
Did you work through this problem? I am encountering the same thing with interFoam now, and would be interested to know how to resolve it. R |
October 1, 2010, 17:15 |
#3 | |
i think its problem was for using system folder of another solver instead of pisoFoam and fvsolution and etc was not proper for pisoFoam. |
May 2, 2011, 17:11 |
Arnout
Rep Power: 15 |
Regarding the error:
The solver needs to know what and where the reference pressure is. Add the following to your fvsolution file: PISO { ... pRefPoint (-0.081 -0.0257 8.01); pRefValue 1e5; } |
July 24, 2012, 05:12 |
Disabled
Rep Power: 15 |
hi everyone, this thread is probably "closed" because "solved",...
nevertheless i have a problem concerning just this pressure referencing, i hope somebody can help: i'd like to sim a channel flow with pisoFoam (ras - if that maybe the cause of the problem, which i think is/should be unlikely), my checkMesh output gives ...Overall domain bounding box (0 0 -0.053) (0.99 0.031 0.053)... for my referencing i have in fvSolution PISO { ... pRefPoint (0.99 0.031 0); pRefValue 8e5; } still, when i run the solver, i get the following error message: --> FOAM FATAL IO ERROR: Unable to set reference cell for field p Reference point pRefPoint (0.99 0.031 0.053) found on 0 domains (should be one) file: /home/users/<...>/run/multiphase/<...>/system/fvSolution::PISO from line 157 to line 167. From function void Foam::setRefCell ( const volScalarField&, const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 95. FOAM exiting *** any suggestions? i should mention that i'm not quite an expert on code manipulation, if there might be a hint in the error output on what is actually going wrong , i might not have seen it. in that case, i would appreciate it if someone could shed some light... |
July 24, 2012, 05:24 |
Bernhard
Rep Power: 22 |
It is a bit tricky, but the point that you use to define the reference cell, is on the boundary, and not inside the domain. Something like pRefPoint (0.899 0.0309 0); should select the desired cell.
July 24, 2012, 06:13 |
Disabled
Rep Power: 15 |
thx for the quick reply...
i thought about that too and tried 0.0309999 but without success,... but now i tried "every" parameter (x, y, z inside) and it worked... anyone an idea why it doesnt work though? it works for interfoam?! ***EDIT*** is this (= not working if point is ON boundary) a bug or intended? Last edited by anon_g; July 24, 2012 at 06:45. |
July 24, 2012, 06:38 |
Bernhard
Rep Power: 22 |
Probably z=0 is exactly on a cell face, so you should try a slightly bigger scalar there as well.
cavity, les, pisofoam |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
MRFSimpleFOAM goes divergenced! | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 19, 2009 02:11 |
Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 05:36 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
