Extremely high Temperature needed to simulate pressurization with rhoCentralFoam |
August 6, 2010, 07:35 |
Dennis Rown
Rep Power: 17 |
Hello Foamers,
I am trying to simulate pressurization inside a tube with rhoCentralFoam. With setFields I set a small area inside the tube that has high pressure (2 GPa). The static pressure is 100000 Pa. When I start to simulate, pressurization takes place but simulation crashes after less than 0.001 s. The temperature I chose for the high pressure field is 4500 K. If I set the Temperatue inside the high pressure field to 20000 K the simulation does not crash but I am very assure that this value is too high. Is this a setup issue? Do you know a way to calculate the needed temperature to set inside the high-pressure field? Thanks in advance! |
natural convection with high temperature gradient? | phsieh2005 | Main CFD Forum | 5 | September 23, 2015 09:25 |
Extremely high Epsilon | Phil | FLUENT | 2 | September 10, 2007 06:25 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
high temperature object in water | mike | Main CFD Forum | 5 | September 1, 2004 13:11 |
Too high maximum gas temperature | Ossi | Siemens | 4 | October 11, 2001 06:13 |
