July 31, 2010, 22:44 |
Trouble with Multisolver installation...
Raman
Rep Power: 16 |
Hey....i tried installing multisolver on OpenFOAM 1.7, but when try running
cd $WM_PROJECT_DIR/src/multiSolver wmake libso I get the message... /bin/sh: cannot create linux64GccDPOpt/options: Permission denied make: *** [linux64GccDPOpt/options] Error 2 /opt/openfoam170/wmake/MakefileFiles:39: linux64GccDPOpt/options: No such file or directory make: *** No rule to make target `linux64GccDPOpt/options'. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created Can u help me with this, I think it is due to a permission issue, but ane idea, how i can go past tht??? I would be thankful if you could tell me tht... |
August 1, 2010, 14:54 |
Alberto Passalacqua
Rep Power: 36 |
Spamming has to be fun! You asked the same question in three threads.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
August 1, 2010, 19:13 |
Apologies!!!
Raman
Rep Power: 16 |
Sry abt tht...didn't want to do tht...but i just wanted a quick reply....won't do tht again!!!
August 1, 2010, 22:08 |
Alberto Passalacqua
Rep Power: 36 |
Fine
It seems you are using the Debian/Ubuntu packages, or an installation out of your /home, so you do not have write permission there. You can probably fix this by setting the destination of multisolver in your local OpenFOAM directory (FOAM_USER_APPBIN) in the Make/files file. Best,
August 2, 2010, 04:49 |
What is Multisolver
ata kamyabi
Rep Power: 18 |
Hi
I have a primary question. Would you explain me what is Multisolver? Thanks a lot Best regards Ata |
August 2, 2010, 10:18 |
#6 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Ata,
Best regards, Bruno
August 2, 2010, 12:34 |
Thanks
ata kamyabi
Rep Power: 18 |
Hi Bruno
Thank you very much. Best regards Ata |
multisolver, permission |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 10:40 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
Problems with installation of OpenFoam | sheyer | OpenFOAM Installation | 8 | July 28, 2008 04:45 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 14:29 |
