attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000;
Like Tree2Likes
Old   October 12, 2016, 19:25
Default Setting JANAF-limits
  #21
Bernhard Linseisen
Linse is on a distinguished road
Dear Ahmed,
Did you think of the obvious - and probably cleanest - solution already? If you know the polynomials are sufficiently accurate for your simulations even below the limits, simply change the limits within the polynomial definition!
Within your "constant"-folder you should find the definitions of the gas properties for the simulation. Possibly they are within a file called "thermo.compressibleGas" or something similar. In a subsection of the file you will find parameters called "thermodynamics", where "Tlow" provides the lower limit for your Janaf-polynomials as read by reactingFoam.
Setting this limit to 280 should minimize the number of warnings in your case.
But be aware: This obviously will completely switch off any warning concerning temperature limits above that limit. If you want to be informed for temperatures between 280 and 300 K, you probably should find another solution...
Cheers,
Bernhard
Linse is offline   Reply With Quote
Old   October 13, 2016, 13:22
Sheikh Ahmed
sahmed is on a distinguished road
Hello Bernhard
Thanks for your suggestion. In the recent chemical kinetic mechanism that I use, I have my Tlow as low as 200 for all the species. Even with that, I got janaf out of reach error msg. This has now been a global problem for all combustion solver users and there must be an inherent bug in the code. I think the developers should concentrate on it.
Please share if you have any other suggestion.
Thanks once again
~SFA
sahmed is offline   Reply With Quote
Old   October 13, 2016, 17:13
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello. As I know there is a bug in openFoam 2.1.1 which leads to nonphysical results: Cooling during compression.
Here is example:
https://www.youtube.com/watch?v=KA--7CpiCTA
Unfortunately I can't find report of this bug.
It is fixed in openFoam 2.2.1.
sheaker is offline   Reply With Quote
Old   May 22, 2018, 10:22
Jinguo Sun
sunjg13 is on a distinguished road
Originally Posted by sahmed View Post
I solved the problem by decreasing the number of cores in my parallel runs. It is working fine now without showing any warning msg and taking unnecessary times.
Hope this will help others.
Yes, it really helps a lot!!!
The last piece of this thread is the most useful one, I think
Of course, I hope we can find some other ways to get rid of this problem.
sunjg13 is offline   Reply With Quote
Old   March 23, 2022, 18:47
Aero_Cats!
IFX21 is on a distinguished road
I solved this problem by reducing the timestep "deltaT" in "controlDict" files. The error disappears but still need some investigation on what really goes behind it
IFX21 is offline   Reply With Quote
Old   February 26, 2023, 22:06
xinyu
lliyuu is on a distinguished road
I have been troubled by the same problem for several months, who can help me, thank you very much.
lliyuu is offline   Reply With Quote
Coal gasification (coalChemistryFoam) N. A. OpenFOAM 12 June 29, 2017 08:22
Tubrogrid - Error on cut-off at TE Flavio CFX 5 January 12, 2017 10:41
DieselFoam and temperature out of janaf range hoogland OpenFOAM Running, Solving & CFD 5 January 28, 2016 13:30
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Residence time per temperature range Roman FLUENT 0 February 16, 2000 02:58
