BCs at Inlet and Outlet
Old   July 28, 2010, 11:46
Default BCs at Inlet and Outlet
Sebastian Saegeler
sebastian is on a distinguished road
Hi!
As I have just started using Open Foam I would need some help to set a case
I want to compare a calculation of a nozzle flow, made with Fluent to one with Open Foam and need to install similar boundary conditions in Open Foam as used in Fluent.
At the inlets, in Fluent I have installed pressure-inlets to set up the total pressure. Furthermore, at the outlets, there are defined pressure-outlets with a given static pressure.
Now I want to do the same in my OpenFoam case. Which BC would you recommend (also in respect of possible backflow)? Also, which BC should be used for k and epsilon? In Fluent I set the trubulence intensity and the viscosity ratio as fixed values. I think the turbulentIntensityKineticEnergyInlet for k is the corresponding BC in OpenFoam. But what to use for epsilon?
Thanks in advance!
Regards,
Sebastian
sebastian is offline   Reply With Quote
Old   July 29, 2010, 15:11
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi Sebastian
For full boundary conditions in O.F. see \src\finiteVolume\fields\fvPatchFields folder.
Good luck
Best regards
Ata
ata is offline   Reply With Quote
Old   July 30, 2010, 05:09
astein is on a distinguished road
This might help as a basic introduction (easy to find with google of forum search...)
http://www.openfoam.com/docs/user/boundaries.php
In the folder Ata mentioned, you'll find a totalPressure boundary condition as well. For a fixed (static) back pressure, try fixedValue with the pressure as value.
-Andreas.
astein is offline   Reply With Quote
Old   May 10, 2013, 23:34
sqing
Sunxing is on a distinguished road
Hi Sebastian
Have you set your case correctly? I have met the similar situation as yours, however there are something wrong in my case that I can't figure out. So I want to get some help from you.
regards
Sunxing
Sunxing is offline   Reply With Quote
