MPI Error - simpleFoam - Floating Point Exception
Old   July 25, 2010, 21:07
Default simpleFoam - Floating Point Exception
Scott
scott is on a distinguished road
Hi there,
I am simulating flow over a vehicle, simple geometry using komegaSST, about 4 million cells, on 4 cores with 8GB ram.
I am getting the following error in Serial and Parallel after just over 500 iterations.
Any ideas as to what could be causing the issue? I have tried a few times restarting from 500 its and it fails each time at 527 its. I am specifying velocity inlet, p=0 everywhere... Could someone please let me know what settings they are using for a similar problem using SST. I have symmetry on sidewalls and roof, moving ground, inlet and outlet.
Best Regards,
Scott
Parallel
linux@linux ~/Desktop/Test_4m $ mpirun -np 4 simpleFoam -parallel >Log2
[2] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #2 in "/lib/libc.so.6"
[2] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #4 Foam:perator*(Foam::tmp<Foam::Field<double> > const&, Foam::UList<double> const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #5 Foam::fvMatrix<double>::relax(double) in "/opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[2] #6 Foam::incompressible::RASModels::kOmegaSST::correc t() in "/opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so"
[2] #7
[2] in "/opt/openfoam170/applications/bin/linux64GccDPOpt/simpleFoam"
[2] #8 __libc_start_main in "/lib/libc.so.6"
[2] #9
[linux:03538] *** Process received signal ***
[linux:03538] Signal: Floating point exception (8)
[linux:03538] Signal code: (-6)
[linux:03538] Failing at address: 0x3e800000dd2
[linux:03538] [ 0] /lib/libc.so.6(+0x33af0) [0x7fab2d233af0]
[linux:03538] [ 1] /lib/libc.so.6(gsignal+0x35) [0x7fab2d233a75]
[linux:03538] [ 2] /lib/libc.so.6(+0x33af0) [0x7fab2d233af0]
[linux:03538] [ 3] /opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam8multiplyERNS_5FieldIdEERKN S_5UListIdEES6_+0xc1) [0x7fab2e202ba1]
[linux:03538] [ 4] /opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4FoammlERKNS_3tmpINS_5FieldIdEEE ERKNS_5UListIdEE+0x48) [0x7fab2e206058]
[linux:03538] [ 5] /opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so(_ZN4Foam8fvMatrixIdE 5relaxEd+0x753) [0x7fab2f5b52b3]
[linux:03538] [ 6] /opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so(_ZN4Foam14incompress ible9RASModels9kOmegaSST7correctEv+0x1b23) [0x7fab2f5f02c3]
[linux:03538] [ 7] simpleFoam() [0x416855]
[linux:03538] [ 8] /lib/libc.so.6(__libc_start_main+0xfd) [0x7fab2d21ec4d]
[linux:03538] [ 9] simpleFoam() [0x414269]
[linux:03538] *** End of error message ***
mpirun noticed that process rank 2 with PID 3538 on node linux exited on signal 8 (Floating point exception).
Serial
simpleFoam >LogSerial
scott is offline   Reply With Quote
Old   July 25, 2010, 23:30
Scott
I'm just going to check this using a known K-E setup that I have used before, so I'll see what happens and might need to look into my SST setup in a bit more detail...
Could it be something in the discretisation schemes etc that I have set incorrectly? I am using all of the defaults.
If anyone has had a similar problem and has sorted it out, or has an SST setup for a similar external aero problem then your help would be greatly appreciated!
Regards,
Scott
Old   August 23, 2010, 03:14
Post Problem regarding MPI
Deevyendu is on a distinguished road
hii to all .. i had installed OPENMPI in my mandriva linux . i am able to compile the MPI program but unable to run the program . I am using DUAL core processor. of intel. during giving command as mpirun -np 2 'filename' , i am getting an error like
error while loading shared libraries: libmpi_f90.so.0: cannot open shared object file: No such file or directory
so anyone con help me regarding this.
Deevyendu is offline   Reply With Quote
Old   April 13, 2012, 17:34
0.1 watts is on a distinguished road
I had the same error occur due to a patch which I had deleted from the CAD model but accidentally left a reference to it in controlDict::functions::forces:atches. Worked fine after I deleted the nonexistent patch.
0.1 watts is offline   Reply With Quote
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
floating point exception? syd STAR-CCM+ 3 April 20, 2010 19:55
Floating point exception error with small DeltaT rassilon OpenFOAM Running, Solving & CFD 19 September 2, 2009 08:39
turbFoam floating point exception and k-epsilon Hectux OpenFOAM Running, Solving & CFD 4 April 28, 2009 08:10
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
