July 14, 2010, 10:38 |
cubicCorrected
yafuji aki
Rep Power: 16 |
Dear FOAMers,
After changing divSchemes as follows, divSchemes { div(rho*phi,U) Gauss limitedLinearV 0.1 phi; div(phi,alpha) Gauss cubicCorrected; div(phirb,alpha) Gauss cubicCorrected; div(phi,k) Gauss cubicCorrected; div(phi,epsilon) Gauss cubicCorrected; div(phi,R) Gauss cubicCorrected; div(R) Gauss cubicCorrected; div(phi,nuTilda) Gauss cubicCorrected; div((nuEff*dev(grad(U).T()))) Gauss cubicCorrected; } I receive an error message "Unknown discretisation scheme cubicCorrected". Is cubicCorrected implemented in OF 1.6??? I can see it on Table 4.10 in the User Guide. If possible, please send me information... Thanks in advance! aki |
August 2, 2010, 11:53 |
Nick Gardiner
Rep Power: 17 |
Hi Aki
I'm not sure about 1.6 but it isn't on 1.5-dev. Without seeing the error it's not so easy to say but I imagine it's the last line that's causing the problem so try: div((nuEff*dev(grad(U).T()))) Gauss cubic; which should work and then maybe: div((nuEff*dev(grad(U).T()))) Gauss cubicCorrected phi; if the original error says something about trying to read beyond EOF Cheers Nick |
August 2, 2010, 11:54 |
Nick Gardiner
Rep Power: 17 |
If that doesn't work it's not implemented. You should get a list of available schemes in the error. If it's not there try 1.7!
August 5, 2010, 04:52 |
yafuji aki
Rep Power: 16 |
Dear Nick
Thank you for replying my question! I modify the divSchemes as you suggested, ------------------------------ div(rho*phi,U) Gauss cubic; div(phi,alpha) Gauss cubic; div(phirb,alpha) Gauss cubic; ------------------------------ and I can start the calculation! (It seems that cubicCorrected is not implemented in OF 1.6...) Thank you very much!! aki |
