July 13, 2010, 11:10 |
Warning message
stephane sanchi
Rep Power: 18 |
Hello OF-users,
I have the following warning message when I launch a case: --> FOAM Warning : From function dlLibraryTable:pen(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 78 could not load libparMetisDecompositionMethod.so: cannot open shared object file: No such file or directory I get the same message when I launch decomposePar. The decomposition works and the case runs well (I think) but why this warning message. Regards, Stephane. |
July 13, 2010, 11:35 |
#2 | |
Niklas Nordin
Rep Power: 29 |
Did you recently upgrade to 1.7?
in system/controlDict you have a line that reads libs ( "libParMetisDecompositionMethod.so" ); Thats what it complains about. Nothing that will produce more than a warning when it cant find the lib, bit if you want to get rid of it, it should be changed to libs ( "libParMetisDecomp.so" ); Quote:
July 13, 2010, 12:02 |
stephane sanchi
Rep Power: 18 |
Thanks, it works.
Now the warning message has disappeared. Stephane. |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit | coompressor | OpenFOAM Installation | 0 | November 12, 2008 20:53 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
