mpirun and selfcoded fvPatchField: "attempt to access element from zero sized list" |
July 12, 2010, 11:22 |
Rep Power: 16 |
Hi guys,
I have the following issue: I coded my own fvPatchField, which inerhits the "mixedFvPatchField" and is compiled as s shared library and added to the controlDict. In a serial run, everything works fine. Running the same case in an parallel run on two processors yields to an error such as: ############################## [1] attempt to access element from zero sized list [1] [1] From function UList<T>::checkIndex(const label) [1] in file /XXXXXX/OpenFOAM//OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/UListI.H at line 105. [1] FOAM parallel run aborting ############################## I doublechecked, that the boundary using my BC has not been cut by the domain decomposition, so there should be no problems here. As well it is interesting, that the error comes from the processor, where my BC is NOT located. Running the very same case with the same decomposeParDict but changing to another BC works fine, so I do believe there is an error in my BC. Has anybody a hint for me how I could locate the error? How could I analyze what list the process tries to access? Any ideas are appreciated, thanks for helping! -Andreas. |
July 13, 2010, 05:43 |
Stefan Herbert
Rep Power: 17 |
Hi Andreas,
just be aware, that your code is executed on every processor separately. So take care, that nothing is done if you don't have any patch faces on one of the processors. Of course it is impossible to tell you, where exactly this error comes from without knowing your piece of code. Regards, Stefan |
July 14, 2010, 05:49 |
#3 | |
Rep Power: 16 |
Hi Herbert,
I am not really sure what you mean with Quote:
Any idea how to find out what the second processor really does with that boundary condition? After the domaindecompostion, the BC is still stated in the different fields of both processors, so the BCs have to be read somehow by all processors. Print-Statements in the constructors of the BC and checking with mpirunDebug did not give any success. Again, any help is appreciated. Thanks in advance! -Andreas. |
mpirun and selfcoded fvPatchField: "attempt to access element from zero sized list" | astein | OpenFOAM | 0 | July 12, 2010 11:05 |
