pimpleFoam Body Force
Like Tree11Likes
Old   October 24, 2016, 00:50
Default How should I define a acceleration-terms.dat in FvOptions-tabulatedAccelerationSource
  #21
金恒
jinheng is on a distinguished road
hi everyone, I want to define a time-change acceleration in sloshing movement. And maybe Fvoptions is a good way. Similar with tanksloshing3D6dof case in interDyMFoam. I want to define a acceleration term in non-inertial reference frame in interFoam. But I can not read the acceleration-term.dat using Fvoptions due to the formate of file.
So my question is :
1、Is there anywhere tell the formate of tabulatedaccelerationsource.
2、otherthan fvoptions, is there any good method to achieve non-inertial reference frame in interFoam. (I have try to added a "acc" just in the Uequ ,but the alpha.water does not change with "acc")
thanks very much for any advises or help.
Usage
Example usage:
\verbatim
SBM
type tabulatedAccelerationSource;
active yes;
tabulatedAccelerationSourceCoeffs
timeDataFileName "constant/acceleration-terms.dat";
\endverbatim
heng Jin
OUC
jinheng is offline   Reply With Quote
Old   October 24, 2016, 04:15
金恒
So my question is :
Usage
Example usage:
\verbatim
SBM
active yes;
\endverbatim
heng Jin
OUC
And I have attempted this thread in CFD-ONLINE(http://www.cfd-online.com/Forums/ope...blefile-h.html). I use the same format of the tablefile. But it still give me the same errors:
1、Expected a '(' while reading Tuple2, found on line 2 the label 0
2、wrong token type - expected Scalar, found on line 2 the punctuation token '('
Old   May 16, 2018, 08:40
Dr. Peyman Davvalo Khongar
peyman.davvalo.khongar is on a distinguished road
Moi!
Check this:
https://github.com/OpenFOAM/OpenFOAM...5900ea5eb546af
Moikka!
Peyman
peyman.davvalo.khongar is offline   Reply With Quote
Old   June 17, 2021, 06:07
Shuo Mi
Msure is on a distinguished road
Originally Posted by be_inspired View Post
Hi Alberto,
In case the force is managed in the first way ( force term in the flux), my question is if Ueqn must be modified or not.
I am working over the rotorDiskSource (OF2.3.0) and some pressure wiggles happen when discreted body forces are included directly over the Ueqn.
I think that your approach could improve this situation.
http://www.openfoam.org/mantisbt/view.php?id=1313
A*U = H + F
I think it should be:
A*U = H - grad[p] + F
U=H/A - 1/A*grad[p] + F/A
Excuse me for using the same topic but there are other topics where others have reported this bug and no answer have been given.
http://www.cfd-online.com/Forums/ope...rce-model.html
http://www.cfd-online.com/Forums/ope...l-wiggles.html
I am trying to implement the body force in this other way and I am not able to do it correctly. Could you please help me?
Have you solved the problem? I am adding a direct force immersed boundary method into pimpleFoam, if I add the extra force from solid in the momentum predictor step, it can run but the results are wrong. I think I should add the force in pressure iterative step, because the force is chaging in every step. Thanks.
Msure is offline   Reply With Quote
Old   November 4, 2021, 21:59
mohammad
mostanad is on a distinguished road
Originally Posted by Msure View Post
Hi Shuo,
Have you solved the problem? I am doing the same thing for IBM, but the results are so dependent on the Number of Piso loops. I think something is wrong with the way I am imposing my force in pressure piso loop. So can you please share to me your experience?
Cheers,
Mohammad
mostanad is offline   Reply With Quote
body force, pimplefoam, source term
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 09:54
DPM Body Force Sandilya Garimella FLUENT 1 April 8, 2008 04:30
Problems with SUPG body force term FEM question Main CFD Forum 0 January 21, 2006 18:51
how to include body force in cfx selvam R.P CFX 4 November 25, 2005 05:01
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 04:06
