Turning interDymFoam into a turbulence solver |
June 29, 2010, 15:06 |
Saśl Balsa
Rep Power: 16 |
I am working with the interDymSolver, working with the sloshing2Dtank tutorial suited to my specific problem. I already performed a simulation in laminar regime and everything worked OK. Now I need to perform the same simulation with a kEpsilon turbulence model. I found some threads on the forum providing same guidance on it, namely, H.Weller stated the next,
"interDyMFoam is setup for laminar flow. If you want to use it for turbulent flow simply transfer the turbulence model parts from either rasInterFoam for RAS or lesInterFoam for LES. " I copied all the files on the rasInterFoam model (dambreak) and adapted them all to my case. When I started running the case the next error message came up: MacBook-Pro-de-Saul:BMark_Roll_Keps saul$ interDyMFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : interDyMFoam Date : Jun 29 2010 Time : 19:46:53 Host : MacBook-Pro-de-Saul.local PID : 663 Case : /Users/saul/OpenFOAM/saul-1.5/run/tutorials/interDyMFoam/BMark_Roll_Keps nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function SDA Reading environmentalProperties Reading field pd Reading field gamma Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting RAS turbulence model kEpsilon keyword pRefProbe is undefined in dictionary "/Users/saul/OpenFOAM/saul-1.5/run/tutorials/interDyMFoam/BMark_Roll_Keps/system/fvSolution::PISO" file: /Users/saul/OpenFOAM/saul-1.5/run/tutorials/interDyMFoam/BMark_Roll_Keps/system/fvSolution::PISO from line 70 to line 75. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 271. FOAM exiting I have lack of experience with the OpenFOAM programming language so after checking the fvSolution I had no many other tricks to use ... Can anyone tell me where the mistake could be? Ths! Saśl |
June 29, 2010, 15:18 |
angel
Rep Power: 17 |
Probably you need to define it, something like PISO { momentumPredictor no; nCorrectors 3; nNonOrthogonalCorrectors 0; nAlphaCorr 1; nAlphaSubCycles 4; cAlpha 2; correctPhi no; pRefPoint (0 0.02 0.251); pRefValue 1e5; } best |
June 29, 2010, 16:24 |
Saśl Balsa
Rep Power: 16 |
Thx Angel,
What I've done so far on this regard is the next, PISO { momentumPredictor no; nCorrectors 3; nNonOrthogonalCorrectors 0; nGammaCorr 1; nGammaSubCycles 4; cGamma 2; } ...this is what is written on the fvSolution dictionary. I did not add your last two sentences. pRefPoint (0 0.02 0.251); pRefValue 1e5; ...before adding them onto the dictionary, could you please give me an idea of their purpose? Thx. Best Saśl |
June 30, 2010, 17:09 |
Saśl Balsa
Rep Power: 16 |
I found that those lines are for the PISO algorithm to set up a reference pressure for calculations ... so , bearing that in mind, I wrote those two lines adapting to my case but it still does not work.
The OpenFOAM complains about the same error ... not pRefProbe defined on controlDict dictionary ... Any idea on where is mistake? What I did do far is to copy all the files from the rasInterFoam to the interDymFoam, but suited to my case. Then I switched the model to turbulence (kEpsilon) on the RASProperties dict. Dont know wether is too much left to do. Any further guidance I'd need to know??? Thx Saśl |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 18:15 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 21:28 |
Turbulence boundary values | lego | CFX | 9 | October 25, 2002 12:55 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 05:24 |
