Multiple reactiveclouds
Old   June 25, 2010, 10:30
Default Multiple reactiveclouds
83_Ale_83's Avatar
Alessandro
83_Ale_83 is on a distinguished road
Hi to everybody,
I am trying to simulate particle tracking inside a rectangular domain. The aim of this simulation is to evaluate the influence of differents diameters of particles. I'd like to introduce inside the domain, at the same time in the same position, 3 or 4 differents types of particles with differents diameters. Could someone help me?
Another question: I am not sure to have understood the difference between parcels and particles, any advise?
Thanks in advance
Alessandro
83_Ale_83 is offline   Reply With Quote
Old   June 28, 2010, 05:12
Sebastian Vogl
sebastian_vogl is on a distinguished road
Hi Alessandro,
I had the same problem like you 2 years before.
So I had a nice question and answer session with Mr Nordin, who was so polite to answer to all of my posts. The link below will guide you to the site:
http://www.cfd-online.com/Forums/openfoam-solving/57854-dieselfoam-spray-2.html
If there is something left for you to know, you can post again.
Best regards,
Sebastian
P.S.: I just foud out that the automatic linking to the address above doesn't work although it is correct. So you have to type the address into your browser manually (copy -> paste).
sebastian_vogl is offline   Reply With Quote
Old   June 28, 2010, 09:18
83_Ale_83's Avatar
Alessandro
Originally Posted by sebastian_vogl View Post
Hi Alessandro,
Best regards,
Sebastian
Thanks a lot for your replay,
I have to read very carefully your topic, seems to be very interesting..You have used dieselFoam and I am using reactingParcelFoam, could be a problem?
Old   June 28, 2010, 12:19
Sebastian Vogl
Hi Alessandro,
I don't know reactingParcelFoam as I am working with O.F 1.5.x and this solver doesn't exist in this version of O.F.
However, I think if you understand how to set up a case (injection of single droplets) in dieselFoam, you will be able to transfer the method to your appplication.
Otherwise I can only give you the standard advise (which probably will not help you very much) to check the code.
Usually all C++ classes, which refer to the particle tracking, are located in the src/lagrangian folder.
Best regards,
Sebastian
defining epsilon for multiple partitions dlogue OpenFOAM Running, Solving & CFD 0 May 20, 2010 12:41
Multiple domain/Multiple material problems... possible or not? Amiga500 OpenFOAM 1 April 14, 2010 16:32
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 16:20
multiple custom mesh in proam user1 Siemens 10 April 8, 2008 11:34
Multiple reference frames? Moon Siemens 0 March 4, 2003 07:32
