solidWallHeatFluxTemperature at the solid solid interface in chtMultiRegionSimpleFoam |
September 23, 2010, 05:31 |
#21 |
Pawel Sosnowski
Rep Power: 18 |
Hello Michael,
as you pointed out, with the geometry that you have shown, it will be veeery hard (or even impossible) to acquire constant heat flux on the solidBottom-fluid interface. Its just the matter of geometry and heat transfer properties. The "hole" is closer to the heating surface, so it will faster start giving heat to the fluid, ergo it will have different heat flux from the rest of the interface. And it will change further in time... With your proposed setup it is unavoidable. In my opinion what you should do is simply... drop the bottomSolid Then at the fluidBottom-patch you just impose solidWallHeatFlux and voilą. Best, Pawel ps In the 4th post in this thread Maddalena cited my talk regarding general idea of temperature coupled systems. I am sure you already read it, but just want to point it out once again |
September 24, 2010, 06:50 |
Heat flux
#22 |
Rep Power: 17 |
Hi everyone!
It turns out that I didn't fully understand the changeDictionaryDict files since I get the following: --> FOAM FATAL ERROR: Not Implemented Trying to construct an genericFvPatchField on patch fluid_to_heater of field h As I undestand it, the problem lies in the coupling between fluid and solid for the temperature. I post my two changeDictionaryDict-files and a picture of the geometry. This is for the fluid: ************************************************** ************ dictionaryReplacement { U { internalField uniform (0.001 0 0); boundaryField { ".*" { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform ( 0.145 0 0 ); } outlet { type zeroGradient; } } } T { internalField uniform 293; boundaryField { ".*" { type zeroGradient; } inlet { type fixedValue; value uniform 293; } outlet { type zeroGradient; } "fluid_to_.*" { type solidWallMixedTemperatureCoupled; neighbourFieldName T; K K; value uniform 293; } } } epsilon { internalField uniform 1.33e-7; boundaryField { ".*" { type epsilonWallFunction; value uniform 1.33e-7; } inlet { type fixedValue; value uniform 1.33e-7; } outlet { type zeroGradient; } } } k { internalField uniform 1.08e-4; boundaryField { ".*" { type kqRWallFunction; value uniform 1.08e-4; } inlet { type fixedValue; value uniform 1.08e-4; } maxX { type zeroGradient; } } } p { internalField uniform 1e-9; boundaryField { ".*" { type zeroGradient; } outlet { type fixedValue; value uniform 0; } } } } ************************************************** ************ And this is for the solid, I do not really understand how it works at the beginning under "boundary". I think there might be errors there as well: ************************************************** ************ dictionaryReplacement { boundary { minX { type patch; } maxX { type patch; } minY { type patch; } minZ { type patch; } maxZ { type patch; } } T { internalField uniform 293; boundaryField { ".*" { type zeroGradient; value uniform 293; } "heater_to_.*" { type solidWallHeatFluxTemperatureCoupled; neighbourFieldName T; K K; value uniform 293; } cellWall { type fixedGradient; value uniform 4860; } } } rho { internalField uniform 8000; boundaryField { ".*" { type calculated; value uniform 8000; } } } K { internalField uniform 16; boundaryField { ".*" { type zeroGradient; value uniform 16; } } } cp { internalField uniform 450; boundaryField { ".*" { type zeroGradient; value uniform 450; } } } } ************************************************** ************ Since the heater splits the fluid, do I have a similar scenario as Michael with the dimple? Should I maybe do a separate region that splits the fluid in the middle? Regards Marco |
September 24, 2010, 07:12 |
#23 |
Pawel Sosnowski
Rep Power: 18 |
Hi Marco,
regarding splitting solid region into "heater part" and "fluid wall" part. This is only a good idea if you want to drop the bottom heater part, leaving only the fluid and the wall, and imposing constant heat flux from the bottom. If you want on the other hand to have the temperature distribution also in the bottom solid part, I would strongly recommend to leave the solid as one, single region (of course if the solid has constant heat transport properties). I do not know whether you read some of my earlier post, but I have some doubts regarding the coupling condition- that is why I think the less solidWallMixedtemperautreCoupled conditions in the simulation- the better. And also, I do not want to discourage you, for sure learning how changeDictionaryDict works is a nice thing, but... don't you think it would be much easier and faster to write your boundaries manually? And then, when your simulation is running, you can try to dig through changeDictionaryDict on a dummy case. Best, Pawel |
September 24, 2010, 07:35 |
#24 | |||
Rep Power: 17 |
Hi Pawel and thank you for the quick reply!
Regards Marco |
September 24, 2010, 08:49 |
#25 | |||
maddalena
Rep Power: 23 |
as Pawel told you, you can leave changeDictionary out... In any case, I noticed the following: Quote:
"heater_to_.*" { type solidWallHeatFluxTemperature; K K; // Name of K field q uniform 1000; // Heat flux / [W/m2] value uniform 300.0; // Initial temperature / [K] gradient uniform 0.0; // Initial gradient / [K/m] } Quote:
This may be not the solution to your problem, but hope it helps. Quote:
Regards, mad |
September 24, 2010, 08:52 |
#26 |
Pawel Sosnowski
Rep Power: 18 |
Hi Marco,
by writing BC by yourself, I mean setting up the case from scratch, without using changeDictionary utility. Lets look at it from the top- what does chengeDict do? It is an utility which allows to prepare the case automatically. It helps to create p, rho, T, U, K (all necessary fields) in "0" folder. My point is that you can do it manually, just writing those files by yourself. And that way changeDict becomes unimportant, and can not generate errors because you know what are the boundaries (in the end you wrote them). Best, Pawel |
September 24, 2010, 14:17 |
#27 |
Rep Power: 17 |
Hi!
That sounds like a good idea actually, I will try to create the files in the 0-directory myself. I did never realize that you could get around it in that way since I thought the cht-solver worked that way (with changeDict) and it was the whole point using them. Should I create two folders inside named "fluid" and "heater" for the respective region? Now my question is how to define the coupling between fluid and solid in the 0-directory since it will have some "internal faces" (fluid to solid-coupling inside the geometry). Don't know if it can be defined in blockMeshDict, if it's ever needed to. I suppose the makeCellSets is still needed to split the geometry. Regards Marco |
September 24, 2010, 15:33 |
#28 |
Pawel Sosnowski
Rep Power: 18 |
Hi Marco,
if you want to have a quite clear understanding how to couple two regions, I strongly recommend to read this thread. It is very long, true, but has all the info you need. If you do not want to read all of it, start from the end best, Pawel |
October 1, 2010, 11:24 |
#29 | |
Rep Power: 17 |
Thank you Pawel!
I read through the entire thread and it was very informative. This was not clear to me though: Quote:
And what do you mean with decomposition? Regards Marco |
October 2, 2010, 04:59 |
#30 |
Pawel Sosnowski
Rep Power: 18 |
Hi Marco,
next time please give me some link to the post that you are mentioning- it was half a year ago This post was about preparing a "case" for work. The idea in cht-tutorial was: create one big mesh, then use splitMesh tool to decompose it into regions. splitMesh writes the decomposed big mesh in "constant" folders in newly created time folder 0.001. I did not like this way, so I proposed to create a tmp case, where one plays with the mesh, and when everything is ready- copies the tmp to runCase folder and runs the simulation. Thats it. Best, Pawel |
October 13, 2010, 15:28 |
#31 | ||||
Rep Power: 17 |
I suppose I create the mesh with blockMeshDict as ususal but how do I define which parts that are solid/fluid? Quote:
http://www.cfd-online.com/Forums/att...iregfolder.jpg About the different regions: Quote:
Thanks for your patience and your replies! Regards Marco |
October 14, 2010, 06:32 |
#32 |
Pawel Sosnowski
Rep Power: 18 |
OK, lets do it from the top.
First thing to know is how OF stores data. It requires folders: system, constant, <time>. Data are stored in time folders and do not contain any mesh information. Mesh is stored in polyMesh folder. It can be put in two places. First, most common is inside constant folder. Second place is the time folder. The 2nd approach is usually used for time-varying mesh. In one of previous chtMRFoam tutorials one also used this approach while running splitMesh. In multi region case, in each of folders: system, constant, <time>, one requires to put "domain" folders. Each of those folders contains data which correspond to a specific region. The regions themselves are defied in constant/regionProperties file. Going back to case organization regarding mesh. I do not like the 2nd approach, that is why I recommended the pre-processing procedure "tmp- run_case". First we create mesh in "tmp" which is saved using the 1st approach, and then manually we move it to constant/domainNames/polyMesh folders to acquire 2nd way of organizing files. After that we create "run_case" and use it to run the case. Regarding "blockMeshDict"- this file is used only during pre-processing to create the mesh. After that, when you want to run the solver it is no longer needed (and even can be deleted). I really do not know how to put this topic in other way For the last words, I want to show completely different way of pre-processing. Create empty multi-region case "runCASE" (without files, just right folder structure). Create a "TMP" case. In it, create a blockMeshDict for only one region. Run blockMesh. Copy acquired mesh from TMP to respective "runCASE" constant/region/polyMesh. Repeat procedure for all reigons. After mesh is created, one has to organize "boundary" files in the right way, create initial fields, etc. This procedure is slower, requires more work but it works. And after one succeeds, he finally knows how it all works. Best, Pawel |
October 19, 2010, 16:30 |
#33 |
Rep Power: 17 |
It's clear to me now, thank you!
Now I know exactly what the boundaries are by defining everything myself (like you proposed) and editing the files for example: Code:
... fluid_to_solid { type directMappedWall; // Changed from wall to directMappedWall nFaces 10300; // Leave as it is startFace 600000; // Leave as it is // Added for coupling sampleMode nearestPatchFace; sampleRegion solid; samplePatch solid_to_fluid; offset (0 0 0); } ... * controlDict file in TMP/system * blockMeshDict had to be in TMP/constant/polyMesh I guess these are basic and obvious things you need to know in OpenFOAM that I didn't know, but now anyone that didn't know can read this and learn . Anyhow, I still get the following error when I try to run chtMRSimpleFoam: Code:
--> FOAM FATAL ERROR: Not Implemented Trying to construct an genericFvPatchField on patch fluid_to_solid of field h If anyone wan't to look at the files your welcome to do so (only the more relevant files are included). The reason I have two solid regions are for visualization purpose mostly since the channel -region will be a more complex geometry later on (running some testcase now to get it working). Just in case someone was wondering. Regards Marco |
October 19, 2010, 17:02 |
#34 | |
maddalena
Rep Power: 23 |
Hi Marco,
usually that error means that you mispelled the boundary definition (in constant\polyMesh\boundary) or the BC assignation (in 0\...). Indeed: Quote:
Have fun! mad |
October 20, 2010, 09:42 |
#35 | ||
Rep Power: 17 |
When I check the boundary- file in the tutorial case (which runs changeDictionary) the created type is directMappedWall. Why the difference? As I carefully read through some earlier posts, you guys didn't actually recommend solidWallMixedTemperatureCoupled (swMtc). For instance: Quote:
Btw, is solidWallHeatFluxTemperature (swHFt) a suitable boundary condition for a system? Since the others (swtc, swMtc, swHFtc) are more like coupling conditions inside the system. I will continue to look for misspelling errors for the moment, could be more more of them (if you have time I posted the relevant files in my earlier post so you can look at them ). Regards Marco |
October 20, 2010, 09:56 |
#36 | ||
maddalena
Rep Power: 23 |
Regards, mad |
October 20, 2010, 12:12 |
#37 | |
Rep Power: 17 |
Hmm, swMtc maybe don't work so well then.
I looked at the other alternatives, but the question is: Do these even exist in OF-1.6.x? * swtc (solidWallTemperatureCoupled) * swHFtc (solidWallHeatFluxTemperatureCoupled) I did try anyway to do as proposed by Pawel in another post by using swHFtc and swtc: Quote:
Could it be something with the thermophysical properties in fluid region? Wondering since the error is displayed in the following way. Code:
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> --> FOAM FATAL ERROR: Not Implemented Trying to construct an genericFvPatchField on patch fluid_to_solid of field h From function genericFvPatchField<Type>::genericFvPatchField(const fvPatch& p, const DimensionedField<Type, volMesh>& iF) in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 45. Regards Marco |
November 4, 2010, 09:32 |
#38 |
Michael Stiehm
Rep Power: 16 |
Hello everybody,
i did some cht-simulation but i“m still confused about the mixing BC. I use solidWallMixedTemperatureCoupled as it was mentioned in this thread. But how does this BC works? That I found out is, that the valueFraction decides whether it is fixedValue ( valueFraction=0) or zeroGradient (valueFraction=1) or it could be something in between. The valueFraction is calulated by: valueFraction()=nbrKDelta/(nbrKDelta+myKDelta) with: nbrKDelta = nbr.Field.K()*nbrPatch.deltaCoeffs(); myKDelta = K()*patch.deltaCoeffs(); so the valueFraction depends on the Kfield of the coupeld regions. What I don“t know is the meaning of the "deltaCoeffs()" and how does the BC work, when the valueFraction is between 0 and 1??? Thanks a lot!! Michael |
November 4, 2010, 10:42 |
#39 |
Pawel Sosnowski
Rep Power: 18 |
Hello Michael,
I suppose that you are working on OF-1.7.1 (please state if otherwise- there were some major changes in this BC). You got quite deep into C++ jungle of boundary condition implementation. As I mentioned, there were big changes since OF-1.6 and this BC became very abstract (this means- good knowledge of C++ is needed). Regarding deltaCoeffs(). It is a member function called for "patch" object which is of "fvPatch" type. Here is where the deltaCoeffs are calculated: makeDeltaCoeffs() In general, they are distances from the face to the centre of the cell. Regarding valueFraction(), etc. In the newest swMixedTempCoupled one just sets valueFraction, rfValue and refGradient, then calls "mixedFvPatchScalarField::updateCoeffs();" and lets OF magic do the rest. In fact, during solving process, OF calls member functions of mixedFvPatchField, which define values, gradients and all the other needed stuff. And those functions take as parameters the ref-Data set by us in the updateCoeffs() of swMixedTempCoupled function. If you want to see exactly how the values are calculated- go to mixedFvPatchField above. All above is just about the "mechanics" of the BC (and requires only jumping from tree to tree in the C++ jungle). I can not help with the theoretical background of this mechanics: I am simply not aware of it- my bad. Can anyone give some references please? Hope it helps a bit, best, Pawel |
November 10, 2010, 13:07 |
#40 |
Michael Stiehm
Rep Power: 16 |
Hello Pawel,
Thank you and yes it helps a lot! So this BC decides due to the K-value and the cellsize whether it is fixedGradient, fixedvalue or something in between. So this BC is the implementation of the third type of BC (other names I found for that are Robin-BC or Newton-BC). Am I right?? Thanks Michael |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
