April 7, 2020, 11:22 |
#41 |
Nicolas Lussier Clément
Rep Power: 17 |
Jonathon Sumner Is the one that was working on log treatment at Bottom.
The link for my work at the time is there I did a short resume of part of Sumner work at the time (p. 14). You can see (p. 19 ) the top BC I use and the reason why. One difficulty of using gradient at the top is that convergence is a lot slower. To fix that I would initialized the hole domain. I did a 1d simulation then initialize the domain with it. I did the same for inlet (use the 1d simulation for the inset). http://espace.etsmtl.ca/id/eprint/1153/ Hope this help a little. Bon confinement et n'oubli pas de t'amuser René. Au plaisir de parler de vive voix un jours. |
April 8, 2020, 09:03 |
#42 |
René Thibault
Rep Power: 7 |
Hi Nic!
Thanks again for your guidance! I followed the modification that I've seen in your thesis, read some papers including the same one that you pointed me out (Sumner J. & Masson C. k-e simulation of neutral atmospheric boundary layer: analysis....) and I still got this weird curve/shape(two peak) for "k". The wind profile is not exactly the same also, worst at mid-length then at the Outlet. I suspect couple of things: 1-Maybe the modification perform in "nutkWallFunction" and "epsilonWallFunction" file are not well done. 2-Maybe the constant Cs (use in "nutkWallFunction") is not right regarding the "z0" I use. 3-Maybe the gradient value I used for "du/dz" and "de/dz" are not right. I'll keep trying to dig in and looking what go wrong........ Bon confinement aussi!! Héhé! On peut se parler de vive voix certainement et comparer comment vous vivez le confinement dans votre coin! Je vais essayer de te trouver sur FB! :P Take care! RT |
April 28, 2020, 12:13 |
#43 |
Herpes Free Engineer
Rep Power: 13 |
Might the following be related:
ENH: Improve and verify atmBoundaryLayerInlet conditions including "tutorials/verificationAndValidation/atmosphericFlows/HargreavesWright_2007"
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
July 4, 2023, 04:51 |
Peak in k and turbulence intensity
#44 |
Teresa Sun
Rep Power: 5 |
Dear all,
I use OpenFOAM/v2106-foss-2021a to simulate the wind turbine with pimpleFoam using large-eddy simulation. The boundary condition for the viscosity at the bottom wall is atmNutUWallFunction. The inlet BC for velocity is atmBoundaryLayerInletVelocity. The mean velocity matches experimental data quite well. However, there is a spike close to the bottom wall in the turbulent kinetic energy profiles and the turbulence intensity. (The green line in the figure is OF results) Any help would be appreciated. Code:
0.org/U #include "include/initialConditions" dimensions [0 1 -1 0 0 0 0]; internalField uniform $flowVelocity; boundaryField { outlet { type inletOutlet; inletValue uniform (0 0 0); value $internalField; } inlet { //type fixedValue; //value $internalField; type atmBoundaryLayerInletVelocity; #include "include/ABLConditions" } ground { type uniformFixedValue; value uniform (0 0 0); uniformValue constant (0 0 0); } #include "include/sideAndTopPatches" } Code:
0.org/nut dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { #include "include/ABLConditions" inlet { type fixedValue; value $internalField; } outlet { type fixedValue; value $internalField; } ground { type atmNutUWallFunction; //type atmNutkWallFunction; boundNut true; ///zero-bounda nut near wall z0 $z0; value uniform 0.0; #include "include/ABLConditions" //Cmu 0.09; //kappa 0.41; //type fixedValue; //value uniform 0.0; } #include "include/sideAndTopPatches" } Code:
0.org/p #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; internalField uniform $pressure; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform $pressure; } ground { type zeroGradient; } #include "include/sideAndTopPatches" } Code:
0.orig/include/ABLConditions Uref 2.8; //Reference mean streamwise flow speed at Zref being used in u* extimations [m/s] Zref 0.125; //Reference height being used in u* estimations[m] zDir (0 0 1); //Ground-normal direction flowDir (1 0 0); //flow direction d uniform 0.0; //Displacement height // I = 1%, u* = 0.1377 z0 uniform 0.03e-3; Code:
0.orig/include/sideAndTopPatches top { type slip; } "(front|back)" { type cyclic; } "proc.*" { type processor; } Last edited by Teresa Sun; July 4, 2023 at 06:08. |
July 4, 2023, 05:51 |
Value in atmNutUWallFunction BC is missing
#45 |
Teresa Sun
Rep Power: 5 |
According to the merge request https://develop.openfoam.com/Develop...e_requests/354, the bug of value in atmNutUWallFunction and atmNutkWallFunction BC is fixed.
However in my case, the simulation is aborted while running on a single processor if I don't provide the value. Code:
0.org/nut dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { #include "include/ABLConditions" inlet { type fixedValue; value $internalField; } outlet { type fixedValue; value $internalField; } ground { type atmNutUWallFunction; //type atmNutkWallFunction; boundNut true; ///zero-bounda nut near wall z0 $z0; //value uniform 0.0; //Cmu 0.09; //kappa 0.41; #include "include/ABLConditions" //type fixedValue; //value uniform 0.0; } #include "include/sideAndTopPatches" } --> FOAM FATAL IO ERROR: (openfoam-2106) Essential entry 'value' missing on patch ground file: /home/jingsun/input_windTurb/1WTM_25/0/nut.boundaryField.ground at line 38. From Foam::fvPatchField<Type>::fvPatchField(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&, bool) [with Type = double] in file /sw/arch/Centos8/EB_production/2021/software/OpenFOAM/v2106-foss-2021a/OpenFOAM-v2106/src/finiteVolume/lnInclude/fvPatchField.C at line 131. FOAM exiting #0 Foam::error::printStack(Foam::Ostream&)malloc_consolidate(): unaligned fastbin chunk detected Aborted (core dumped) |
July 4, 2023, 06:02 |
#46 |
Teresa Sun
Rep Power: 5 |
According to this merge requesthttps://develop.openfoam.com/Develop...e_requests/354, the current ABL boundary conditions are limited to the Neutral-stratified situation.
Does anyone know if these BCs are extended to stable and unstable stratification? |
July 4, 2023, 08:44 |
#47 |
René Thibault
Rep Power: 7 |
Maybe you need to look at SOWFA on github.
July 4, 2023, 10:43 |
#48 |
Teresa Sun
Rep Power: 5 |
Hi Rene,
Thanks for your reply. I studied SOWFA for a while but had to give it up. Because the HPC that I have access to does not support the installation of OpenFOAM6, on which the newest version of SOWFA is implemented. Also, I need to implement my own spatial and time discretization methods and my own large eddy model, which takes a bit of effort but is endurable. I supposed it would be hard to reach for any help once I got stuck in SOWFA. Please correct me if you think differently |
July 4, 2023, 10:55 |
#49 |
René Thibault
Rep Power: 7 |
If you want to developp your own code, its probably the right thing to do. Personnaly, I'm not skill enough to do something like that, but If you are, go for it. |
July 5, 2023, 14:21 |
#50 |
Rep Power: 17 |
Indeed it should not be difficult. In our reach group we where many to have modified it. That is 10 years ago still this is not a complexe modification if you know the equation you want to implement.
November 3, 2023, 04:22 |
#51 | |
María Rosales
Rep Power: 3 |
Hello Teresa,
Did you solver your ABL? I have simulated some using BC's from openfoam, and also happen that K is not kept equal downwind, but looking to articles this happens a lot to other softwares. Even though for simulations R&h proposed this trick for numerical approach, the diffusion we get in k (and not the perfect profile as inlet) is casually similar what happen in nature... One thing that most recent articles avoid to apply is the retarding shear on 1st cell centers that recommended R&H, also R&H recommended to apply face discretization in gradients, something that I have not tried yet If you want to discuss any related to ABL or AD, I'm open to that! Quote:
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 11:24 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Combining BCs: wall - outlet. Boundary layer disappears | MartinaF | OpenFOAM Running, Solving & CFD | 1 | July 20, 2009 19:14 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
