rotating gravity
Old   June 7, 2010, 05:11
Default rotating gravity
Oli
olhe0002 is on a distinguished road
Hello World.
Is it possible to read the gravity-File g time dependent vom a data-File?
(similar to timeVaryingUniformFixedValue)
This could be an easy way to simulate a rotation.
Best Regards.
olhe0002 is offline   Reply With Quote
Old   June 7, 2010, 08:40
Default should not pose a problem
romant's Avatar
Roman Thiele
romant is on a distinguished road
This should not pose a problem. One thing though is that you will have to modify a solver and add a gravity file to your time folders. This can then be read like any other field from the the runtime.
I would suggest that you take a look on how to implement new fields to an existing solver.
~roman
romant is offline   Reply With Quote
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 18:06
Gravity in single rotating reference frame QinxueTan FLUENT 0 May 7, 2008 07:59
On gravity modelling... Drona CFX 7 November 22, 2001 11:28
